dbneutralizer + grungebuster: Ideal or overkill for metal platter?
0 Members and 1 Guest are viewing this topic. Read 3165 times.
6BQ5
For someone using a turntable with a metal platter ...
Would a Way Excellent mat perform just as well as ...
A sheet of Dbneutralizer to dampen the platter resonance with a Grungebuster mat on top?
Certainly the latter is way more expensive. Perhaps overkill?
Herbie
    • Herbie's Audio Lab
The white foam base of the Way Excellent II Turntable Mat is extemely efficient at damping platter resonance. A Way Excellent II Turntable Mat of sufficient thickness (3.7mm or more) will thoroughly decouple and isolate the record from a resonant metal platter.
A dBNeutralizer mat with grungebuster mat on top would not necessarily be overkill, and the result with some tables would be very good; with most tables though, it wouldn't be as good or better than a Way Excellent II, and would add a lot of weight to the platter.
Herbie's Audio Lab
« Last Edit: 23 Aug 2010, 01:26 am by Herbie »
