0 Members and 1 Guest are viewing this topic. Read 7236 times.
the fact that the noise goes from one channel to the other when you switch wires indicates a problem likely unrelated to possible compatibility issues between a koetsu and a vpi. you have a wiring issue - it's either the cartridge itself, or the tonearm wiring. something isn't getting properly grounded...doug s.
This could be a "lab" topic so feel free to move it if necessary.I've just setup a Koetsu rosewood cartridge (demo from a generous AC'er) on my VPI classic TT. I now have a rather loud hum coming from my left speaker- there's really no hiding it with music. As the volume goes up so does the hum. By switching my input on my preamp to cd the hum goes away, so it's only in the TT/cartridge/ phono section. The hum continues w/ different input jacks on the back of the preamp. And all preamp inputs work fine with my digital source.I've swapped out cables, swapped out my vista phono preamp for another demo vista phono pre and the problem continues. I then disconnected the 4 cartridge hookup wires and swapped the left +,- for the right +,- and the hum then resumes in the right speaker. The previous cartridge (similar Low output MC Benz glider) had no problems. What does this mean and how do I get rid of the hum?TIA,Rob s.
I now have a rather loud hum coming from my left speaker- there's really no hiding it with music. I then disconnected the 4 cartridge hookup wires and swapped the left +,- for the right +,- and the hum then resumes in the right speaker. The
Well, there is your problem. The chassis/arm of the turntable needs to be grounded to the phono preamp or preamp. Please connect ground wire between the 2 and hum will go away.Wayner
ok, grounded the TT to the phono pre. Hum still there.Rob S.
Quote from: Rob S. on 28 Nov 2009, 02:11 amI now have a rather loud hum coming from my left speaker- there's really no hiding it with music. I then disconnected the 4 cartridge hookup wires and swapped the left +,- for the right +,- and the hum then resumes in the right speaker. The If above is true, it is definitely not a tonearm wiring issue! (1) Hum occurs in both channels when hooked up to L cart outputs, and (2) there is no hum when either channel is connected to R cart outputs.The hum occurs specifically with the L cartridge outputs, therefore the problem is inside the cartridge itself, on the L side.As Barretta used to say...."you can take dat to da bank!"
