QUAD monoblock bias, help!
0 Members and 1 Guest are viewing this topic. Read 3392 times.
ric_lord
« on: 27 Nov 2009, 02:10 pm »
Hi,
Just bought a set of Quad QC24 preamp & II-forty amp's second handed....
I admit, I saw them.. eard them (in the store with lots of background noise)... and I loved them...
Then went back there and bought them giving my semi-new advance acoustics monoblocks in return and more money of course.
Now, I have them for a week and I wonder if they are OK... since the bass coming from my Monitor audio GS60 is way to strong and the mids and highs, I belive should be stronger. In other words the sound is kind of muffled... I belive it should be more airy.
Appart from that the sound if very very defined... and I love that... it is not harsh... it's sweet... I can ear every detail in the music! and for hours and hours  aa
BUT, I'm stressed if there is anything wrong/broken/that needs to be fixed with the amp's/pre-amp.
There is a scratch sound with the volume knob at zero... you can ear it from the sofa... its a low volume sound but is there. This I belive comes from the pre-amp... if I turn it off this sound dissapears.
Is there any way or test I can perform to know if everithing is OK with the Quad's.
I love them and would like to keep them. But if they are not OK maybe I should try to return them and wait until I can afford new ones...
Also, is it possible to bias these quad at home?
richidoo
Re: QUAD monoblock bias, help!
« Reply #1 on: 27 Nov 2009, 03:13 pm »
The II fortys are very smooth, kinda soft edged, you love it or hate it, I'm glad you love it, they are cool little amps. Being voltage source, tube amps respond to variations in speaker impedance with different volume, aka EQ variations. The 3 way crossover nominal 6 ohms could mean it dips low and soars high, I couldn't find an actual impedance graph, you can write to them for it. Anyway, tube amps prefer flat speaker impedance, some are more tolerant than others. Quad II is autobias so don't worry about that. Manual.
http://www.stereophile.com/artdudleylistening/407listen/
This review reveals your speakers' preference for higher power SS amp. You can try stuffing the bass port of the speaker to reduce the volume and tighten up the bass. Theoretically it should go lower but softer, could be just right for you. But it will change the electrical behavior of the drivers too, so listen and see. You can email Monitor to make sure stuffing the port is OK from driver cooling standpoint, or check your manual. If you know someone who is electronically savvy, You may also be able to add a parallel resistor to the bass crossover network to raise its impedance, or a zobel network to flatten an impedance peak. There is also a Quad II Eighty available for last 2 years.
The preamp just has a dirty volume pot, it's normal maintenance. Get some of this from RS - don't use Caig, it leaves residue. Spray it into holes in the pot inside the case. If no holes then spray it down the gap around the shaft. Turn the knob full range many times while it is wet. Let dry before running the preamp, a few minutes. Clean the source selector switch also.
Have fun!  :thumb:
Rich
ric_lord
« Reply #2 on: 28 Nov 2009, 11:56 am »
Thanks!   :D
« Last Edit: 29 Nov 2009, 12:10 am by ric_lord »
