0 Members and 1 Guest are viewing this topic. Read 4759 times.
I recommend the Nikon D90 for $1,031.89 from AmazonThis comes with a nice lens - 18-105mm, which is a very nice lens for a beginner!The D40 is an excellent choice for half the price, if she really doesn't want to get into photography too much. It makes great pictures and is a simpler interface. Also it is smaller and lighter than the D90 but still excellent quality..The D90 is an excellent camera, and is a better deal for the money than the D5000
Any thoughts or suggestions for me?
Quote from: Rob S. on 26 Nov 2009, 06:32 pmAny thoughts or suggestions for me?What you may have deciphered from the posts here so far is that the real decision is whether this is a purchase to get into a camera system or if it's just a single camera+lens combo. If the latter, then a DSLR may well not be the best solution.It may be worth you enquiring of SO what type of photography she intends to pursue. Flowers? Landscapes? People/portraits? Black and white? Just a few shots of the family vacation? Will she be printing them? How large? This question is really more about the lenses than the body - digital bodies will be obsolete next year, lenses will last a lot longer (how long depends on which system...)But if all of that is too much... just get the Nikon
Wow, lots of fanaticism here... ...
Quote from: Andrikos on 10 Dec 2009, 12:53 amWow, lots of fanaticism here... ...Hey! Ain't that the truth. I would say that if you are going to buy just 1 or 2 regular entry level zooms and not couple of the top higher end lens/zooms model one than you shouldn't worry much about which brand. These days all DSLRs under $1K are very capable. Depend on your and your wife need just look for one that you and her like. I guess if your wife is going to be using it than maybe it is good idea to just go to a good camera store with her and check them out. I think something light and easy to use would be a good start for her and you. Well, good luck and have fun. Take care,Buddy
www.dpreview.com will serve you well.
