0 Members and 1 Guest are viewing this topic. Read 19863 times.
Another few comments about power...I seem to be drawn to the sound qualities of low efficiency speakers! Maybe this is because it is easier to design a speaker when efficiency is not so high up on the list of concerns --- when you can waste power on better damping or flattening out the response of the drivers.As far as amps go, give me a 1000W super low noise+distortion amp over a 10W amp any day. If the power output capability of amps had no effect on the other measurable (and unmeasurable) parameters, than there would be no discussion. Coming as close as possible to recreating a live performance is very important to me, and doing so with 10W, even with 120dB/1W speakers is more or less impossible for most music sources, especially if there is any bass.
As quoted Benchmark Media's recommendation regarding amplifier power does not make any sense to me. If the you are operating at 75 to 95 percent of the amplifiers rated power on a continuous basis you have only 25 to 15% of the amplifiers remaining reserve power for peaks. It makes more sense to be operating at 75 to 95% on the worst case peaks thereby hopefully minimizing the possibility of clipping...
Quote from: konut on 29 Nov 2009, 03:23 amWere that it was so easy. High efficiency drivers, typically, are less linear that lower efficiency drivers. Not all lower efficiency drivers compress. Its easy to make generalisations, but knowing how to evaluate individual components goes a long way towards putting together a system that will satisfy the end user.I don't have any desire to get into a debate on the issue, but I am not so sure I buy the less linear statement. If you mean as in less flat FR, well sometimes that is true but many modern HE drivers don't fit that generalization. There are more and more HE drivers meant for other application than ultimate SPL that measure quite flat, as good as many low eff drivers. "Not all lower efficiency drivers compress." I haven't seen one that doesn't. Even the best of the bunch ScanSpeak revelators compress when asked to produce peaks over 100db. There just can't be enough copper in the motor to not heat up, and if there were, they'd have so much inductance there would be no top end. There is no replacement for 10db of sensitivity. Well that is my opinion anyway.
I think this limitation goes unnoticed by most people due to the compression present on almost all of our recordings. If our recordings had little to no compression we would be more likely to notice the more subdued and less lifelike quality the music has due to driver compression. This also may be a case where people can't see the forest for the trees. If virtually all piston type mid-range and tweeter drivers exhibit this problem then most people never hear a speaker system that doesn't have power compression. When people don't know that any alternative to this condition exists they accept the flawed speaker system as normal and it becomes the new standard.That being said I think most people never ask their system to do much that requires them to bump up against this limitation in the course of normal operation.Scotty
I prefer amplifiers with low input sensitivity. They're quieter and allow more travel on a preamp's volume control. They sound better since external and internal influences are minimized.
I'm using speakers with[ 9 ]5" mids and [24] 1" dome tweeters per side. Rated at 94db. Using a 22W SET. Now when I switch to a 250W triode amp the music is effortless, fuller, no compression detected and a more powerfull midbass. Why? charles
