6X5 Rectifier
0 Members and 1 Guest are viewing this topic. Read 3140 times.
Bigfish
6X5 Rectifier
« on: 22 Nov 2009, 08:40 pm »
Guys:
What do you recommend as the best 6X5 Rectifier Tube?
Ken
Berndt
Re: 6X5 Rectifier
« Reply #1 on: 12 Dec 2009, 11:18 pm »
I sold my collection but was partial to the coke bottle "G" tubes.
Big Red Machine
Re: 6X5 Rectifier
« Reply #2 on: 16 Dec 2009, 01:10 pm »
I found a Mullard on Ebay and am awaiting it to give it a try in my Mapleshade.  I was a little surprised how this tube in the power supply affects the sound.  Didn't expect it to have such an impact, but it does.
jeffdavison
Re: 6X5 Rectifier
« Reply #3 on: 9 Jan 2010, 04:41 pm »
a little hard to find... The Bendix 5852
has the added benefit of a 45s warm up and a higher PIV of 1375v
A bit pricey when you find them, I think they were averaging around $45 bucks last I looked.
JD
Guys:
Ken
Quiet Earth
Re: 6X5 Rectifier
« Reply #4 on: 5 Apr 2010, 12:25 am »
The Bendix 5852 is not always a drop in replacement for a 6X5. If you notice the AC transformer humming a little louder than normal, then the power supply might be having a difficult time with the 5852.
I like Sylvania 6X5s, GE and Raytheon too.
Bigfish
Re: 6X5 Rectifier
« Reply #5 on: 5 Apr 2010, 01:29 am »
Yes, I purchased a Bendix to use as a rectifier in my Mapletree's Power Supply.  After purchase I learned it is not recommended for use in the Mapletree due to the tube's heater voltage requirement.  I did not think it worth the money and trouble to upgrade the power supply to allow the use of the tube without potential damange.  I ended up purchasing the Mullard Rectifier from the Big Red Machine.
