Community
Non-audio hobbies and interests
The Culinary Circle
woodsyi
Where can I find an appliance bulb cheap!
0 Members and 1 Guest are viewing this topic. Read 2656 times.
Doublej
22 Nov 2009, 02:49 pm »
I need a replacement bulb for my Kitchenaid (Whirpool) stove. It's a small 5 watt bulb (part number 4452164) for the oven. Online sites want $20+...ouch!
Anyone have a cheap source for stuff like this?
Niteshade
Tubes: Audio's glow plug. Get turbocharged!
Re: Where can I find an appliance bulb cheap!
22 Nov 2009, 03:00 pm »
Do you have a hardware store nearby? Our carries some specialty bulbs. We have ACE out here- you may as well since it's a chain.
srb
Reply #2 on:
22 Nov 2009, 03:24 pm »
I don't know if this bulb is somehow special for oven duty, but it seems rather expensive for a 5W 12V 2-pin Halogen bulb.
Here is one that meets the specs (but not specifically an oven bulb):
http://www.lampsplus.com/products/5-Watts-12-Volts-Bi-Pin-Halogen-Light-Bulb__82406.html
As Blair mentioned, you could probably also find it at Ace. If I could find one for $5, I'd probably give it a try and see if it lasts.
ecramer
Volunteer
In time whats deserved always get served.
Reply #3 on:
22 Nov 2009, 03:33 pm »
try home depot or lowes for a start its common bulp ace hardware proably caries it also
(i checked sears ant they want 21.41)
Ed
]http://www.prosupplyco.com/browseproducts/%284452164%29-P1-LIGHT-BULB.HTML]
Community
The Culinary Circle
woodsyi
