PlayWasapi player - claimed better than Foobar
0 Members and 1 Guest are viewing this topic. Read 2279 times.
firedog
« on: 21 Nov 2009, 12:40 pm »
Hi-
See link to thread in another circle: http://www.audiocircle.com/index.php?topic=68364.new#new
about the GUI less player, PlayWasapi. In the "discless circle" it got reviews as better sounding than foobar.
Unfortunately, I can't get it to work right on my machine - error messages.
But maybe some of you would like to try it and report back how it sounds.
Edit: got it to work, the problem was the FLAC install. Reinstalled FLAC on my PC and copied flac.exe to the PlayWasapi folder. After that, everything worked.
Sounds good. Not sure if it's better than Foobar, I'll have to do some more extensive listening.
kaka
Re: PlayWasapi player - claimed better than Foobar
« Reply #1 on: 5 Dec 2009, 11:17 am »
Did you ever reach a verdict ?
