Audio/Video Gear and Systems
The Acoustics Circle
Rob Babcock
Inside Corners
Inside Corners
0 Members and 1 Guest are viewing this topic. Read 1479 times.
honesthoff
Inside Corners
18 Nov 2009, 07:58 pm »
If I'm drywalling a new room, how much would a 1 1/2" radius bullnose inside corner bead help the acoustics? The cost of the bead is minimal, and I think the look itself would be pretty cool. Has anyone tried this? I've attached a link to the product, No. 7066 about half-way down the page.
http://www.trim-tex.com/catalog/112bull.htm
bpape
Industry Participant
I am serious and don't call my Shirley
Re: Inside Corners
18 Nov 2009, 08:02 pm »
For anything under a few kHz, it will do basically nothing. For higher frequencies, it's actually worse than a square corner as the concave radius will focus sound like a lens.
Bryan
honesthoff
Re: Inside Corners
Reply #2 on:
18 Nov 2009, 08:12 pm »
Thanks, Bryan. I am going to laminate some 1/4" rock on the front wall (beat-up from wallpaper removal) and thought it might help to get rid of two 90's.
Rob Babcock
Inside Corners
