Bryston 1b vs. .5B vs. B&K PRO-10MC?
0 Members and 1 Guest are viewing this topic. Read 7361 times.
centaurus3200
« on: 18 Nov 2009, 07:43 pm »
hi all,
i'm currently using a Yamaha C-70 preamp. actually sounds pretty good and i dig the MC phono stage. i actually like it better than my previous preamps - Precision Fidelity C4, Conrad Johnson PV2A, MFA Magus C and some others. however, i'm thinking it's time to move on. i got the C-70 for free so it's hard to complain, but i do wonder what i'm missing in analog resolution.
don't want to blow a ton of money, so thinking conservativley between the 1b, .5b or B&K or ??? basically any decent solid-state preamp with an MC phono stage for under $300.
current system for reference:
McIntosh MC60 tube monoblocks
Yamaha C-70 preamp
Theta DSPro GEN III DAC
Theta Data III transport
Yamaha NS-1000M speakers
REL Q100 sub
Adcom ACE-515 conditioner
Technics SL-1600MK2 turntable with cardas rewire
Spectral MCR Signature with van den hul retip
thanks,
Robby
werd
Re: Bryston 1b vs. .5B vs. B&K PRO-10MC?
« Reply #1 on: 18 Nov 2009, 07:49 pm »
hi all,
Yamaha C-70 preamp
REL Q100 sub
thanks,
Robby
Look for a Carver C-2. I have one and its my back up pre. Excellent phono stage and they are very cheap on Agon. Full solid state.
centaurus3200
« Reply #2 on: 18 Nov 2009, 07:54 pm »
thanks for the tip on the carver. quick question as far as the 1b and .5b. i thought they all had MM and MC inputs. but i've seen a few of both models for sale where the owners say their unit only has moving magnet but no moving coil stage. is this correct?
thanks,
Robby
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 18 Nov 2009, 07:57 pm »
thanks,
Robby
Hi Robby,
Correct - the 1B came with or without MM or MC and the .5B was only with or without MM.
james
centaurus3200
« Reply #4 on: 18 Nov 2009, 08:02 pm »
interesting James. so to confirm - you could either get the 1b with both MM and MC or two phono outputs of MM OR MC. the .5b did not have MC? i thought it did.
Robby
thanks,
Robby
Hi Robbie,
james
« Reply #5 on: 18 Nov 2009, 08:05 pm »
Robby
thanks,
Robby
Hi Robbie,
james
Correct the .5B does not have a big enough chassis to allow for a MC stage.
james
