which speakers for my room?
0 Members and 1 Guest are viewing this topic. Read 1373 times.
mms3
« on: 14 Nov 2009, 03:56 am »
I'm looking to upgrade my speakers (KEF iQ series), and it seems like there are quite a few good options from GR Research.  I'm in the process of buying a new house, and it has an open floor plan.  The room I'll put the speakers in is roughly 16 x 16 x 9 with one side open to the rest of the house.  Can I make LS6's work in this room, or should I be considering OB7's or N3's?  They will be for 70% movies/30% music.  It isn't a dedicated room, so there will be some WAF limitations on what I can do for accoustic treatments.
Thanks in advance for any advice.
S Clark
Re: which speakers for my room?
« Reply #1 on: 14 Nov 2009, 06:17 am »
They should all be able to work reasonably well and provide excellent, full sound.  Having said that, the LS6's are just something special.  :thumb:
Will2
« Reply #2 on: 14 Nov 2009, 11:59 am »
You might want to consider one of the "V" series of speakers - there are three.  They aren't on Danny's web site but if you look through the threads in this circle you will find them.  Basically, there is a small version that is more reasonable and has a better WAF (the V2), a bigger version that is less expensive and not "all-out" (the V1), and an "all-out" version (the Super V).  I would suspect one of these is the best to go with as long as you can position them a little away from the walls (I think 3 feet is what is called for).  I'm very far from an expert but I think the nice thing about them for dual HT and music duty is that they have subs built-in so you won't have to place separate subs in the room (adding to the WAF and convenience).
Enjoy the search
Will
