Cabinet size for driver
0 Members and 1 Guest are viewing this topic. Read 1154 times.
persisting1
« on: 13 Nov 2009, 03:15 pm »
Hey all,
Wanted to know the smallest size sealed cabinet (single driver) that I can build according to each driver. Both driver wont be used in the same cabinet.  I'll use the one that will use the smallest cabinet. They will be used to cover 80Hz-200Hz.
HiVi M6N 6"
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=297-441%20%20%20%20%20%20%20%20&FTR=HiVi%20M6N&CFID=2201178&CFTOKEN=60887871
http://www.parts-express.com/pdf/297-441.pdf
Dayton RS125S-8 5"
http://www.parts-express.com/pe/pshowdetl.cfm?&DID=7&Partnumber=295-360&ctab=2#Tabs
http://www.parts-express.com/pdf/295-360s.pdf
If anyone could recommend a different driver than the two listed, that would be able to hit 80-200Hz in a small enclosure, I'm all ears :wave:
NagysAudio
    • http://www.nagysaudio.com
Re: Cabinet size for driver
« Reply #1 on: 13 Nov 2009, 04:33 pm »
You can use this website, it has correct calculators for many different types of speaker enclosures. www.carstereo.com
For your first woofer:
Box Volume: 0.433ft. cubed (12.26L)
Frequency Response: F3=72.28Hz
For your second woofer:
Box Volume: 0.214tf. cubed (6.06L)
Frequency Response: F3=103.67Hz
JoshK
« Reply #2 on: 13 Nov 2009, 05:44 pm »
I use unibox, google it, it is a free excel spreadsheet that calculates box alignments.  It took me a tiny bit to figure it out but I think there are walk through tutorials online now.
There is also WinISD, but I haven't used it.
S Clark
« Reply #3 on: 13 Nov 2009, 06:01 pm »
WinISD is very easy and reasonably accurate- I've used it lots of times.  Also, you might look at the M-130 5 1/2" driver from GR-Research.  I've used the Dayton driver you have listed, but the break up modes required a more complex crossover.  The M130 is so smooth that you could get by with a single inductor, although I'd recommend some baffle step compensation.
http://www.gr-research.com/index.asp?PageAction=VIEWPROD&ProdID=110
persisting1
« Reply #4 on: 14 Nov 2009, 02:17 am »
Thanks for the help and links  :thumb:
Anyone else know of a driver that works well in a small enclosure?
