0 Members and 1 Guest are viewing this topic. Read 3515 times.
Hi guys, my apologies as this does not directly relate to R.W.A. (sorry Vinnie ).Just a couple of simple questions : I have a class d amp module which I have briefly tried with two 2ah SLA video camera batteries wired in series. The sound just blew me away!Question is : can I use car batteries?(yes I know the risks).Any help is much appreciated!Cheers,Rob.
Are they of low enough impedance compared to SLA's?
here are a number of posts on other forums/websites that indicate that a car battery can be used providing adequate room ventilation is provide in the charging cycle.Anyone else care to comment on the possibilities of this?
I recall visiting a large specialist battery store where I noticed that they were charging a normal flooded cell inside the shop.Further to that, some of the so called sealed batteries showed signs of fluid leakage.
My demand on them is very light and my charger is more of a trickle charge so it doesn't stress the batteries either.
This is a fascinating topic. I've heard of the advantages of powering audio equipment with batteries but never thought about doing it with auto batteries. What equipment is required to take an audio system off grid? In my case I have a a tube preamp and tube monoblocs. I already power my Mac and Musicstreamer+ through my Mac's battery. Thanks, Don
Without getting in to a debate on whether car batteries are safe to use in a home environment with an amplifier that under normal use would require minimal charge times, it appears that others HAVE used car batteries quite successfully.There are a number of posts on other forums/websites that indicate that a car battery can be used providing adequate room ventilation is provide in the charging cycle.Anyone else care to comment on the possibilities of this?I recall visiting a large specialist battery store where I noticed that they were charging a normal flooded cell inside the shop.Further to that, some of the so called sealed batteries showed signs of fluid leakage.
