New Musica Bella Linestage - The 'Basis'
0 Members and 1 Guest are viewing this topic. Read 1727 times.
Bill Baker
    • Musica Bella Audio
« on: 10 Nov 2009, 06:39 pm »
The Musica Bella "Basis" linestage is a custom tube linestage built around one 6SN7 dual triode per channel. Keeping in the Musica Bella tradition, the 'Basis' provides a clean, linear presentation with low distortion using a simple SRPP circuit.
The "Basis" was developed to fill in the void in the Musica Bella line for a tube linestage as the BellaMax gets moved up to the Purity Audio Design product line. Our goal with the "Basis" was to bring to you a quality vacuum tube linestage in custom real wood veneer chassis at an entry level price point.
Volume is handled by a 23 position stepped attenuator using Dale/Vishay RN 1% resistors. Full function remote control option is also available.
The chassis design allows for quick and easy tube rolling with the tubes accessible through the top. The chassis is constructed of Baltic Birch Ply then covered in real wood veneer. Aluminum or hardwood control knobs are available.
Further details: http://www.bellaextreme.com/basis%20linestage.htm
« Last Edit: 18 Nov 2009, 11:51 pm by Response Audio »
Bill Baker
Re: New Musica Bella Linestage -
« Reply #1 on: 18 Nov 2009, 11:49 pm »
Here are a couple pictures of a finished Basis linestage. This unit is finished in Cherry real wood veneer with aluminum knobs. The lower picture is a chassis arrangement done in Figured Koa prior to any sanding or finishing.
