Stands for HT-1
0 Members and 1 Guest are viewing this topic. Read 2709 times.
twisted karma
Stands for HT-1
« on: 10 Nov 2009, 03:18 pm »
I am needing some stands for my wonderful HT-1's. I know at one time that Jim liked the Dayton stands. That particular model is discontinued on Parts Express and could be hard to come by. Are there any other stands I should be looking into?
nyc_paramedic
Re: Stands for HT-1
« Reply #1 on: 10 Nov 2009, 04:05 pm »
Sound Anchors? They make custom and adjustable stands.
http://www.soundanchors.com/
Re: Stands for HT-1
« Reply #2 on: 10 Nov 2009, 04:24 pm »
Not sure if the wood/color would match but check out these
http://www.audiocircle.com/index.php?topic=70369.msg692636;topicseen#new
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
Re: Stands for HT-1
« Reply #3 on: 10 Nov 2009, 04:39 pm »
newzooreview
Re: Stands for HT-1
« Reply #4 on: 10 Nov 2009, 06:50 pm »
Another nod for Skylan. A terrific fellow, and the stands are nicely engineered and have a less industrial appearance than the sound anchors that I've seen. I used to own a pair and would buy them again if I needed stands. They usually take about 3 weeks to build and ship. He can make them exactly the height that you want and customize the top plate size as well. The price is very good too (for high quality stands).
If the Skylan look isn't for you, Tyler Acoustics also sells stands that can be customized in height and are sand-fillable. They might fit better with some decor (they look a bit more like Greek columns).
evan1
Re: Stands for HT-1
« Reply #5 on: 10 Nov 2009, 09:15 pm »
Why not ask Jim to build you a pair in a matching veneer
twisted karma
Re: Stands for HT-1
« Reply #6 on: 12 Nov 2009, 01:49 pm »
Thank you all so much for the different options on stands. It is much appreciated!
Bill@LakeGeorge
Re: Stands for HT-1
« Reply #7 on: 13 Nov 2009, 11:04 am »
I had Jim build me a stand for my HT Center speaker.  It matches perfectly, highly recommened. :thumb:
mdfoy
Re: Stands for HT-1
« Reply #8 on: 13 Nov 2009, 04:22 pm »
Bill,
I have the 4 post sound anchors for my pair of HT-1,and highly recommend it :thumb:
