Newcomer
0 Members and 1 Guest are viewing this topic. Read 2035 times.
Caustic Casey
  • "All government, of course, is against liberty.."
    • causticcasey.com
Newcomer
« on: 9 Nov 2009, 03:30 pm »
Greetings to all.
This is my first post.
Since we finally own a home of our own, I am seriously preparing to upgrade my audio system.
I have been doing extensive reading on speaker reviews.  Klipsch, Polk, Paradigm, and of course, Salk.
My listening room is 20 x 20, with wood flooring, panelled walls, and a cathedral ceiling.  Probably not the ideal acoustic environment...
I am very interested in the Song series of speakers, but want to be sure they would be right for this type of room.
I will be using them for both music and home theater.
Any input would be greatly appreciated.  In the meantime, I am going to crunch some numbers!
Thanks in advance!
Casey
rahimlee54
Re: Newcomer
« Reply #1 on: 9 Nov 2009, 03:43 pm »
Welcome to the forum.  Depending on how loud you want to listen the salks will be fine, even they will get to loud in a room that size.
Atlplasma
  • Just off the boat
Re: Newcomer
« Reply #2 on: 10 Nov 2009, 02:55 pm »
My room has similar characteristics but with carpet flooring. I have the SongTowers with the ribbon tweeter and am very happy with the audio performance. I have a solid state and tube setup and switch back and forth. The SS setup is a Yamaha 2700 receiver with three Outlaw monoblocks (about 400 watts into 4 ohms). The tube unit is an old Eico ST-70 putting out about 30 watts per channel. In either configuration, I can play my music to ear-bleed levels. I also have an M&K sub that I can include in the SS playback whenever I want a bit of extra bass.
While I don't think you would be disappoint in the SongTowers, you should try to set up a local audition so you can judge their performance for yourself.
Vulcan00
  • SEM Micrograph of Dendritic Structure
Re: Newcomer
« Reply #3 on: 10 Nov 2009, 10:33 pm »
Atlplasma:
I have a M&K sub also currently using. which sub?
Atlplasma
  • Just off the boat
Re: Newcomer
« Reply #4 on: 10 Nov 2009, 11:30 pm »
It's the 1250THX.
fishinbob
Re: Newcomer
« Reply #5 on: 11 Nov 2009, 05:16 pm »
We need a new thread....Salks and old subs.
MX-100 here. :lol:
Vulcan00
Re: Newcomer
« Reply #6 on: 11 Nov 2009, 09:45 pm »
lol
I am using M&k with my new speakers. It does pretty good as long as I tune it in carefully and keep the db down at thx reference or below.
I really would like to have 2 new subs built by the master just for music.
