0 Members and 1 Guest are viewing this topic. Read 9938 times.
Also, not all SETs or SEPs are created equal and having been through more than my share of them, it's nearly impossible to predict how a given amp will sound with your speakers, in your room, anhd with your music.-- Jim
I am using the Metronome design - see http://www.frugel-horn.com/metronome.htmlfor the modified 4.5" Fostex FE127eN (http://www.planet10-hifi.com/FE12xeN.html).I believe very similar driver is used by Ed Schilling (http://www.thehornshoppe.com) in a horn design and he says on his website his speakers work fine with SET amps of 3+Watts.
Now it may be that full-bodied sound at low volume cannot be expected from this size of driver but I am getting incredibly good midrange (compared to my previous Focal JM Lab speakers) and I like the speakers (my first audio diy project) and coherence.Judging my previous posts, I am uncertain with a fullranger with rolled off highs and less strong bass the SET design would bring much extra compared to EL84 push-pull design.Anyway, there is still so much for me to understand about tube amplification and the right matching with speakers that I need to do more learning. Thanks for suggestions given above.
