cass a amp how hot does yours run?
0 Members and 1 Guest are viewing this topic. Read 1579 times.
freo
« on: 9 Nov 2009, 10:42 am »
Greetings from Australia
I have a first watt f3 clone that runs in class a all the time, it gets very hot 68 degrees c anyone else have a class a that runs about the same
Regards Roger
avahifi
    • http://www.avahifi.com
Re: cass a amp how hot does yours run?
« Reply #1 on: 9 Nov 2009, 01:32 pm »
A class A amplifier must be biased on at twice full power output into 8 ohms, or four times full power output into 4 ohms.  A 10 watt per channel class A amplifier that remains class A into 4 ohms will put out 40 watts of heat all the time from each channel, 80 watts total.  You might notice how hot a 100 watt light bulb gets.
68 degrees C is probably quite reasonable for a small class A amplifier.  However if you wanted 200 watts per channel class A, your amp would put out as much heat as a big home electric space heater. :o
Not very "green".
Frank Van Alstine
sts9fan
« Reply #2 on: 9 Nov 2009, 01:45 pm »
My Zen v9 which is pretty much the same as the F3 runs pretty warm but not bad.  I used Conrads biggest sinks I think they are 350mm?  After a few hours on I can still keep my hands on the sink as long as I want.
Wind Chaser
« Reply #3 on: 9 Nov 2009, 01:50 pm »
Such amps in Canada during the winter have a huge WAF.  Green isn't an issue when it's -40. :lol:
turkey
« Reply #4 on: 9 Nov 2009, 03:02 pm »
So your family gathers around the amp in the evening?
Telstar
« Reply #5 on: 12 Nov 2009, 11:45 am »
Regards Roger
My F3 runs hot too. I'll eventually put it in a bigger case with huge heatsink.
