0 Members and 1 Guest are viewing this topic. Read 14385 times.
My walls are all built with 16" spaced studs, and like I said, I'm not worried about inner wall isolation, so the addition of the second wall is not needed.So, I should install fiberglass insulation on the inner wall, and 2x 5/8" drywall on all walls and ceiling?As for adding an extra or isolated ground rod.... that is a very bad suggestion and whoever your electrician and electrical Inspector is, they should be reprimanded...this is a very dangerous practice and against code.How do I know? I have been a Journeyman electrician for over 20 years, IBEW local 112.For electrical, I will be adding an isolation transformer to power all audio circuits.I thank everyone for the suggestions so far, and if there are more, please add them, I'm all ears Rick
QuoteI installed a 12"x7"x18.5' LVL that spans the area where the wall/archway once was. I cut the ceiling joists so that the LVL would fit into them and up against the floor above, making it even stronger.I am trying to visualize the Italic sentence...so you notched out about 50% of the vertical dimension of the support beam at each ceiling joist? And how many floors are there above this?
Quote from: rich121 on 9 Nov 2009, 04:05 pmMy walls are all built with 16" spaced studs, and like I said, I'm not worried about inner wall isolation, so the addition of the second wall is not needed.So, I should install fiberglass insulation on the inner wall, and 2x 5/8" drywall on all walls and ceiling?As for adding an extra or isolated ground rod.... that is a very bad suggestion and whoever your electrician and electrical Inspector is, they should be reprimanded...this is a very dangerous practice and against code.How do I know? I have been a Journeyman electrician for over 20 years, IBEW local 112.For electrical, I will be adding an isolation transformer to power all audio circuits.I thank everyone for the suggestions so far, and if there are more, please add them, I'm all ears RickThe use of additional or separate grounding for a stereo is pretty common practice and as far as I am aware does not break any regulations.http://www.russandrews.com/product.asp?src=google&lookup=1®ion=UK¤cy=GBP&pf_id=1201&customer_id=PAA1006117109947EBSDYYKUQTMGTMGM
Rick,OK, so now I understand the structural comments. Having the 18.5 inch deep laminated beam (LVL for the straights here) hanging down 12.5 inches below the 2x6's across the middle of the ceiling is a bit of a drag, but unavoidable.BTW hospital isolated grounds were only used in anesthetizing (and rarely intensive care) locations due to the prevalent use of oxygen. The grave concerns for explosion also had other safeguards added in operating and delivery rooms including conductive flooring, shoe cover prohibitions, special venting of the rooms, those round/green grounding plugs, and warning signs before entering the suite. Fortunately anesthetics have come a long way since 1976 when they quickly were replaced in hospitals. Some still use isolating grounding to drain current leakage from equipment in the operating rooms away from patient's heart muscles that could cause heart attack. Better surgical equipment build standards have reduced this concern and nowadays the primarily leakage comes from all the documentation equipment and the cheap stereos brought into the rooms. Dropping the requirement for isolated grounding allowed savings of $25,000 per panel and the option to have power from both the normal and critical branches fed to the rooms, so you don't have to fully rely on the emergency transfer switch to work.And with the improved telemetry equipment, concerns related to cell phones use in hospitals have all but gone away in the past 5 years. Cell phones were never a problem with surgical equipment (patient monitoring in recovery yes, but not in the operating or delivery rooms).So have fun with the room, but do try to eliminate those even ratio room dimensions and take care of the doors/windows. Look at the Cardas website. You have the space, you might even want to consider installing extra/interior skewed walls as Cardas shows. (This could also take care of the door/window issues.)
As from the measurements given, the ceiling joists are perpendicular to the header, as they only can be, they were cut to allow the header to be installed within, up to the bottom of the floor above, for added strength, and to hide half the thickness in the ceiling. The joists are attached to the header with joist hangers.
QuoteAs from the measurements given, the ceiling joists are perpendicular to the header, as they only can be, they were cut to allow the header to be installed within, up to the bottom of the floor above, for added strength, and to hide half the thickness in the ceiling. The joists are attached to the header with joist hangers.Ok, now I get the picture. Thanks for the precise explanation.Now I go stand in the line.
Just because someone tells you it's ok to use...and this same person is making money from you in the process... you think it's ok? Your very nieve, and dangerously ignorant.This is a violation in so many ways....read article 250 in the NEC...Anyone that would use this product is putting themselves and others in danger.RickQuote from: Browntrout on 10 Nov 2009, 11:19 amQuote from: rich121 on 9 Nov 2009, 04:05 pmMy walls are all built with 16" spaced studs, and like I said, I'm not worried about inner wall isolation, so the addition of the second wall is not needed.So, I should install fiberglass insulation on the inner wall, and 2x 5/8" drywall on all walls and ceiling?As for adding an extra or isolated ground rod.... that is a very bad suggestion and whoever your electrician and electrical Inspector is, they should be reprimanded...this is a very dangerous practice and against code.How do I know? I have been a Journeyman electrician for over 20 years, IBEW local 112.For electrical, I will be adding an isolation transformer to power all audio circuits.I thank everyone for the suggestions so far, and if there are more, please add them, I'm all ears RickThe use of additional or separate grounding for a stereo is pretty common practice and as far as I am aware does not break any regulations.http://www.russandrews.com/product.asp?src=google&lookup=1®ion=UK¤cy=GBP&pf_id=1201&customer_id=PAA1006117109947EBSDYYKUQTMGTMGM
Quote from: rich121 on 11 Nov 2009, 01:50 amYour very nieve, and dangerously ignorant.Your statement is oxymoronic. "You're very naive." How?
Rick,Plz take a pill. (I'm just trying to extrapolate from your structural descriptions.)BTW I'm a licensed engineer, did structural for 8 eight years and have worked around healthcare for the past 20 years. In the past 5 years have been in charge of updating construction codes for healthcare. You're right about one thing, there are a lot of electrical guys who think they know it all. At least I state what I know and admit to not knowing it all.
Rick,Plz take a pill. (I'm just trying to extrapolate from your structural descriptions.)BTW I'm a licensed engineer, did structural for 8 eight years and have worked around healthcare for the past 20 years. In the past 5 years have been in charge of updating construction codes for healthcare. You're right about one thing, there are a lot of electrical guys who think they know it all. At least I state what I know and admit to not knowing it all.I am an electrician that uses the NEC everyday in my work, yes, I know alot about it, unlike you, who makes false statements in a trade you obviously know very very little about.I showed you were wrong in your statements by providing Code reference, you on the other hand, do not admit to not knowing.I'm quite sure that you don't have much capacity or authority in any "in charge of updating construction codes for Healthcare". These things are done by boards at the State and Federal levelRick
