0 Members and 1 Guest are viewing this topic. Read 1967 times.
Senor Pig....Since you and affordable audio go hand in hand, you gotta check out the Vista Audio ACLE phono stage. This thing is very very good, not just for the money, but period.Myself and many others have commented on it very postitively. Check the Vista circle.For cartridges, lots of good affordable ones out there. From direct experience I can recommend the ones I use (see my signature below). Buy used! I bought both the Dyna and Clearaudio used in the $200 to $300 range!So it is possible to do phono + cartridge for less than $700. Budget prices, but not budget sound.
Concrete?! There's no concrete in there! Acrylic, plexi, shaped metal and chipboard.
