0 Members and 1 Guest are viewing this topic. Read 4986 times.
The amp should be the last component turned on and the first component turned off. If you turn off your amp first, you won't have a pop.
Now it's time to start looking for small appliances (or even a furnace) that is kicking in or out occasionally. Motors can cause this especially. Also some fluorescent lighting turned on and off can cause a spike. Now I really think you are hearing a voltage spike.Wayner
Thanks Nuance. I don't think Audio Refinement is still around, I purchased this used back in June from Agon actually. I'm sorta wondering if this will be an issue that will be tough to repair or not. There's a local place that charges $100 hr, so at that rate if it's going to be a lot of work, I'd probably be just as well off getting a new amp. Thoughts on the type of repairs that may need to be made?And I'll definitely look over that list Nuance I always do like having an excuse to by a new toy!
