Stereo Tube Amp 2A3 45 6SL7 5Y3 Tube Amplifier
0 Members and 1 Guest are viewing this topic. Read 4154 times.
waamamps
    • WaamampS
« on: 7 Nov 2009, 04:46 pm »
    Beautiful, hand built stereo, singled-ended all tube power amplifier using 45, 6SL7 and 5Y3 tubes. This amplifier layout has been carefully designed using a combination of Vintage, and high quality components. These high quality components are brand new and consist of Hammond filter choke, Hammond Filament transformers, Heyboer output transformers, Illinois electrolytic capacitors, Orange Drop (715P type) capacitors, carbon resistors, IEC plug, gold-plated RCA jacks, speaker jacks, ceramic tube sockets, ceramic tube caps and power switch. Coupling capacitors are orange drop (715P type). Illinois electrolytic capacitors are used in the cathode section and Cornell-Dubilier electrolytic capacitors are used in the power supply section. Vintage Marantz dual stereo volume control was used and in the input stage, gold plated shielded wire was used. All components are perfectly matched left to right for proper channel balance. This amplifier was designed on a garolite board, with all handwired, point to point circuitry using less wire to prevent hum and all grounds are in the correct places. This design allows this amp to run continuously, with extreme quiet operation. This amplifier has built in volume control and can be used with or without a preamp. You can connect any fixed or variable source output directly to this amplifier. You can use the audio out from an iPod, CD, DVD, MP3, Computer, TV, XM or SIRUS to the input connection of this amp. Amplifier was designed utilizing four tubes, one 6SL7 (Input) can be substituted with 5691 and two 45 (Output) can be substituted with 2A3 and 1-5Y3 (Rectifier) can be substituted with 5U4. This amplifier features normal input(R/L), volume control, power switch, power indicator, right/left speaker terminals (8 Ohms) and circuit protection. You will be amazed at the bass sound of such a small amplifier. Amp works great into any 4 and 8 ohms speakers.
 Specifications:
Input connector - Two Gold RCA input jacks (Right & Left).
Built-in volume control (does not need a preamp).
You can connect the audio out from an iPod, CD, DVD, MP3, VCR, TV, XM or SIRUS to the input connection.
Tubes 1-6SL7 (Pre-amp), 2-45(Output) and 1-5Y3 (Rectifier).
Normal input (R/L), Volume control, Power switch, IEC plug, Power indicator, Speaker terminals (8 Ohms) and Circuit protection.
Circuit Type: Single-Ended Class A
Power Output: 2 watts x 2
Dimensions: W 13" x D 10" x H 2"
  Custom Made Amplifiers by: WaamampS
 For more info:  www.waamamps.com
 Any questions please email me at [email protected]
Asking $650
« Last Edit: 8 Nov 2009, 12:00 am by waamamps »
