Amp for LCR-15 and TS-150
0 Members and 1 Guest are viewing this topic. Read 1942 times.
Mr_dingo
« on: 5 Nov 2009, 08:02 pm »
Hello.
I have Von Schweikert?s for Surround, and I am looking for a new amp.
Anybody that have tried a Krell amp, like KAV-500 or Showcase?
Suggestions.....come on!  :D
Regards
Dingo
MichiganMike
Re: Amp for LCR-15 and TS-150
« Reply #1 on: 5 Nov 2009, 09:21 pm »
I use a Parasound A51 amp to drive four TS-150 (rear and side surrounds) and a center channel that is a VR4 JR.  (I tried a LCR15 center, but found I preferred a center that matched my left and right front speakers.)  The Parasound A51 is probably overkill for the TS-150, but I wanted an amp similar to the Parasound A21 driving the left and right front speakers.  Most would consider a Krell amp a step up from my amps.
Almost any Krell amp would likely easily power the TS-150 and LCR-15.  Does a Krell amp drive your other channels?
es347
  • ..I've got my eye on you...which one you say?
« Reply #2 on: 5 Nov 2009, 11:18 pm »
mr_dingo...
Are you looking for a 5 channel amp??
Mr_dingo
« Reply #3 on: 6 Nov 2009, 04:37 pm »
Howdy!
Yes box I am looking for a 5 channel amp, it will power 4 TS-150 and 1 LCR-15.
The Krell amp KAV-500 is right price used, but I need a 230V unit hard to get.
The LCR-15 will perhaps be replaced with a GamuT Center in the future.
Amps for Main speakers are GamuT monos.
Thanks.
es347
« Reply #4 on: 6 Nov 2009, 05:33 pm »
I was fortunate to find a B&K REF 200.5 on Ebay.  It was 7 mos. old and I got it for about 40% msrp.  It is very good and I would recommend it highly.  Not sure if it's available with 230V input.  You could always move to the states. :lol:
es347
« Reply #5 on: 6 Nov 2009, 05:40 pm »
mr. dingo..
http://powerampshop.com/parasound-hca-1205a-power-amplifier-thx-no-reserve
Good luck in your search...it's at least half the fun!
MichiganMike
« Reply #6 on: 8 Nov 2009, 10:54 pm »
http://www.htguide.com/forum/archive/index.php4/t-9324.html
The link is to a thread regarding conversion of a Parasound amp from 110V to 230V.  You might look into this possibility for a Parasound A51 or A52, if this is of interest.  Alternatively, you may be able to find a Parasound that has already been converted.
