Lamm LL2 Pre-amplifier
0 Members and 1 Guest are viewing this topic. Read 1540 times.
paularthur
« on: 3 Nov 2009, 05:24 am »
Offered by P.A.U.L.  An Authorized Lamm Dealer
Please see my web page for informaiton about P.A.U.L. and LAMM Ind., Inc.
http://www.precisionaudioonline.com/LAMM.html
SALE Price $3499
MANUFACTURER 2 YEAR WARRANTY
SHOWROOM DEMO
ALL SALES FINAL
The LAMM LL2 has been very slightly changed and is now the LL 2.1 (also available) at just under $6000 ($5990) and again is Class A on 2009 Stereophile Recommended Components and Editors? Choice Awards 2009 in The Absolute Sound.
THIS IS MY LAST ONE.  It is less than 6 months old.
Specifications
Description: Tube line-level stereo preamplifier. Tube complement: two 12AU7A, two 6DJ8, one 6X4. Inputs: 3.
Tape loops: 1.
Frequency response: 1.5Hz?400kHz, ?3dB.
Input impedance: 50k ohms.
Output impedance: 250 ohms.
Input sensitivity: 0.127V RMS, +2%.
Rated output voltage, 20Hz?20kHz: 1.0V RMS.
Harmonic distortion: <0.03% at 2V RMS.
Phase inverting: No.
Dimensions: 19.25" (495mm) W by 5" (130mm) H by 13.75" (350mm) D. Weight: 20 lbs (9kg).
Price: $5390
Considering its price point, the LL2 line stage's level of performance is nothing short of sensational. Its blend of tonal neutrality, speed, control, and harmonic purity add up to a sure recipe for musical excellence. It is capable of competing in the highest audiophile arena, while its slight spatial reticence and textural softness are easy to live with. It should readily integrate with a diverse range of systems. The LL2's ability to drive a variety of amps and exotic cables allows it to comfortably slip into an existing system without adverse complications. Let me take this opportunity to raise my glass in a toast: to Lamm Industries and Vladimir Shushurin for a job well done. Cheers!
