0 Members and 1 Guest are viewing this topic. Read 14900 times.
Here is a working link to the KECES DC-115 (David, you can always click the Preview button and click the links there to test)Nice looking power supply. Any specs on regulation or ripple? Steve
Hi David:Do you have picture of the included DC cables? Just need to make sure they are skinny enough to loop the little hole through my turntable DC motor's casing.Thanks,Ed
Hi,Any luck with the pictures?Thanks
Nice unit. Can you consider giving two 12 volt outputs?How about the noise of the unit? Does it hummmmmmmmmmm?
I notice there is a ferrite core on the cord. How far is the core from the tip on the soldering end? I need at least 7 inches of wire to go into the turntable motor casing.Thanks.
No that is thinking out of the box. GREAT IDEA and a very fair price I may add. good luck.charles
Hello,The ferrite is only on one end of the cable, if you need to hard wire it to your turntable, you can cut off the end without the ferrite core. Please note the cable is professionally made and injection molded, so you can't just unscrew it and desolder, but will need to clip one end off and peel the cable if you need to do that.PS: If you need the end to be pre-cut and tinned before it is shipped out, I can do that free of charge, but please remember to inform me at the time of purchase.
Quote from: Zyca on 26 Dec 2009, 07:05 pmHello,The ferrite is only on one end of the cable, if you need to hard wire it to your turntable, you can cut off the end without the ferrite core. Please note the cable is professionally made and injection molded, so you can't just unscrew it and desolder, but will need to clip one end off and peel the cable if you need to do that.PS: If you need the end to be pre-cut and tinned before it is shipped out, I can do that free of charge, but please remember to inform me at the time of purchase. Hi David:How do I contact you at time of purchase? Also, can you supply me with a plug that I can solder to the end of my existing cable incase the cable supplied with the DC-115 is too thick to go through my turntable motor case? Thanks,Ed
I'd vote for a Squeezebox 5 volt output.
Is there any way to order this without creating an account? I placed it in the cart and want to proceed with Pay Pal and it looks like I have to create an account with the website which I don't want to do.
