A couple of new JBL Array 1400 reviews for 'Laundrew'
0 Members and 1 Guest are viewing this topic. Read 9712 times.
  • The Demo is Everything!
    • http://www.bryston.com
« Last Edit: 2 Nov 2009, 08:26 pm by James Tanner »
Laundrew
Re: A couple of new JBL Array 1400 reviews for 'Laundrew'
« Reply #1 on: 2 Nov 2009, 11:24 pm »
Hello James,
Thank you very much for sharing these reviews with me. I had to do a double take at the quoted price of $18,999.00 mentioned in one of the reviews :o
Thanks again :thumb:
Be well...
« Reply #2 on: 2 Nov 2009, 11:51 pm »
Tom Jung who wrote the second review is a very famous recording engineer.
james
vegasdave
« Reply #3 on: 3 Nov 2009, 03:52 am »
Cool!
vegasdave
« Reply #4 on: 3 Nov 2009, 06:20 pm »
Hey James, would it be ok to drive a 1400 with a 4b?
« Reply #5 on: 3 Nov 2009, 06:28 pm »
Absolutely - they are 89dB efficient so in a normal size room you're fine.
james
vegasdave
« Reply #7 on: 8 Nov 2009, 08:20 pm »
James, do the Arrays represent good value as well as good sound?
« Reply #8 on: 8 Nov 2009, 08:42 pm »
That's a good question Dave. I had a very famous recording engineer over here the other day and he absolutely loved them. What's interesting is some recordings - like some of Bob Dylans old stuff sounds fantastic. Also I have a Reference Recoring 192K/24 I just downloaded of Carmen and it is by far the best I have heard it on the JBL's.
So I guess I am saying that depending on the type of room you have and the music you generally listen too they are really very good indeed.
james
vegasdave
« Reply #9 on: 8 Nov 2009, 09:15 pm »
Well, my current room where I have the Studio L890s is medium sized and is untreated at the moment. It does get a bit lively (I'm in an apartment) at high volumes.
I listen to jazz, blues, and the various sub-genres of rock.
« Reply #10 on: 8 Nov 2009, 09:33 pm »
Horns typically have a very directional polar response so they do very well in lively rooms because there is not as much reflected energy from the room surfaces.
james
vegasdave
« Reply #11 on: 8 Nov 2009, 10:31 pm »
Cool. Sounds good.  Can the Arrays handle high energy music just as well as softer styles?
« Reply #12 on: 8 Nov 2009, 11:38 pm »
In spades!
james
vegasdave
« Reply #13 on: 9 Nov 2009, 12:03 am »
Awesome! Now I've gotta keep saving up. It's gonna be a while...
V
« Reply #14 on: 24 Jun 2010, 10:44 pm »
The Array 1400's are great speakers.
Laundrew, what speakers did you have before you bought the JBLs?
vegasdave
« Reply #15 on: 24 Jun 2010, 10:48 pm »
You mean were...now that they're made in China (cabinets) and Mexico (drivers and assembly) forget it!
V
V
« Reply #17 on: 24 Jun 2010, 10:53 pm »
Vegasdave:
First of all, I want to thank you for many interesting posts on this forum.
I think you should stop writing that Mexico/China thing on JBL time and again, though, until you give us _bulletproof_ and verifiable documentation that it is the case.
vegasdave
« Reply #18 on: 24 Jun 2010, 10:58 pm »
You're welcome. There is documentation. Go here: http://www.audioheritage.org/vbulletin/showthread.php?27692-The-End-of-an-Era
I also spoke with a JBL employee about this matter, and I dunno if I'm allowed to give you his email address. I will ask.
VOLKS
« Reply #19 on: 24 Jun 2010, 11:01 pm »
Anyone want an Eggroll or a Taco?
