Anyone heard Occam Audio's MTM 7?
0 Members and 1 Guest are viewing this topic. Read 5439 times.
persisting1
« on: 2 Nov 2009, 02:45 pm »
Has anyone done business with Occam Audio or heard this speaker?  Can anyone also comment on the CSS SDX7 driver?
Occam Audio
http://www.occamaudio.com/index.html
CSS SDX7
http://www.creativesound.ca/pdf/CSS-SDX7-data-261207.pdf
persisting1
Re: Anyone heard Occam Audio's MTM 7?
« Reply #1 on: 2 Nov 2009, 02:46 pm »
Here's the specs page for the Occam Audio MTM 7 Closed Box Satellite Design.
http://www.occamaudio.com/free.html
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #2 on: 2 Nov 2009, 03:12 pm »
When Al at RAW acoustics was around, they started distributing the SDX drivers which look very cool and competitive at their prices. The drivers are made in Taiwan and the subwoofers are made in China with XBL technology as well. Looks very interesting.
I would ask the designer to provide you with more measurements of the MTM satellite design, especially off axis to 60 degrees at least. That way, you will be able to judge somewhat yourself.
Best,
Anand.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #3 on: 2 Nov 2009, 06:07 pm »
The SDX7 is one of my favorite woofers. It does benefit from a fairly simple cone modification that increases its downward dynamic range and smooths out the response at the top of its passband (coincidently a result that Al measured).
I use 4 as support woofers for my Fonkens, and currently am using a single in a small cube to augment the Alpair 10 boxes currently in the system (and have 3 more cubes awaiting assembly)
I won't comment on the MTM, i'm not a big fan of dome tweeters and XOs in the range usually seem in MTMs or typical cone/dome speakers.
dave
persisting1
« Reply #4 on: 3 Nov 2009, 02:24 am »
Thanks for the help.
I've emailed Occam and I'm now waiting for a reply.
poseidonsvoice
« Reply #5 on: 13 Nov 2009, 03:31 pm »
Just to help you out with your decision, here's a review from Jeff Poth on the MTM 4 from Occam Audio as well.
Best of luck,
Anand.
persisting1
« Reply #6 on: 17 Jan 2010, 10:49 pm »
Well,
I never heard back from them  :nono:
