Cracking noise from 9B SST
0 Members and 1 Guest are viewing this topic. Read 1602 times.
cmreddy
« on: 2 Nov 2009, 05:06 am »
Hi All,
i had crackling noise from center speaker and i was experimenting it with changing the channels.. I have moved left speaker to middle channel. Today I had to paused the movie to take a call and suddenly i heard cracking noise from left speaker even though Oppo was on mute. (As a matter of fact through out the movie, there is a cracking noise coming from the left speaker..) I muted the Onkyo 885 and still no use,, the cracking noise continues.. I feel its the Amp.. Any ideas?
I just wanted to make sure, that its the amp before shipping it to Bryston.. And more over the original box is in shambles.. If at all i have to send it to bryston, do i need to buy another bryston box for 9b SST? thankx
Cm..
  • The Demo is Everything!
    • http://www.bryston.com
Re: Cracking noise from 9B SST
« Reply #1 on: 2 Nov 2009, 04:00 pm »
Hi All,
Cm..
So the crackling followed the speaker?
james
cmreddy
« Reply #2 on: 2 Nov 2009, 04:12 pm »
I switched the speakers and the noise is specific to the center channel of 9B SST.. Today i spoke to Dennis H from Bryston and asked me to send the module back to him with detailed instructions for packaging..
« Reply #3 on: 2 Nov 2009, 04:14 pm »
Ok - I will shut up and go away  :D
cmreddy
« Reply #4 on: 2 Nov 2009, 04:33 pm »
I couldnt think of anything other than the amp that could be causing problems.. But just in case, i also wanted to get other members feedback..
Now i need to search for a place where i could get the Square screw driver.. Thankx
« Reply #5 on: 2 Nov 2009, 04:36 pm »
Hi CM,
It sounded like you said you moved the center channel to the left side and then the left side started crackling?
"I have moved left speaker to middle channel. Today I had to paused the movie to take a call and suddenly i heard cracking noise from left speaker"
cmreddy
« Reply #6 on: 2 Nov 2009, 05:41 pm »
The wording could be tricky.. I am not sure, i conveyed the meaning properly.
Bottom line, the center channel in the 9B SST is having problems and lets call it "CHANNEL".. To rule out the speakers having problem,, i connected Left to the CHANNEL.. Now left speaker started cracking..
I swiched the processor outputs alternating Left and Center.. In every case, the spaker connected to the CHANNEL is cracking..
Looks like i dont have an option but to send the CHANNEL to Bryston Service..
