Casters for HT2-TL?
0 Members and 1 Guest are viewing this topic. Read 2157 times.
oneinthepipe
  • Trainee
    • Salk Signature Sound/Audio by Van Alstine two-channel system
Casters for HT2-TL?
« on: 2 Nov 2009, 03:49 am »
Hi Folks:
I did a search in this circle and didn't find any specific information.
I have been thinking about replacing the speakers' spike with casters.  I found a better position for my speakers, but I am hesitant to leave them there permanently because the right speaker is in the line of traffic, and I worry about damage to the speaker.  I have been moving them but not without damage to the hardwood floor.
Does anyone have a recommendation for casters?  Is there a significant sonic downside to using casters?  Also, does anyone know the thread dimensions?  I could remove a spike and measure the diameter, pitch, and length, but if someone already knows, I won't need to risk moving the speaker.
1 INTHEPIPE
TomS
Re: Casters for HT2-TL?
« Reply #1 on: 2 Nov 2009, 04:01 am »
I put some of these Waxman Floor Sliders on my spiked racks and subs, at least until I decided where everything was to go.
http://74.125.95.132/search?q=cache:AM3VYJ2oxqcJ:www.amazon.com/Waxman-4701395N-Furniture-Sliders-Oatmeal/dp/B000PBA8E2+waxman+floor+sliders&cd=2&hl=en&ct=clnk&gl=us&client=firefox-a
I just dropped the tip of the spike into the little cups on top.  They were about $5 at Menards, Lowes, etc.and worked great on my bamboo floor.
satfrat
« Reply #2 on: 2 Nov 2009, 04:19 am »
You might want to visit Herbie's Audio Lab  circle here on AudioCircle. Herbie's got some dandy Little Fat Gliders that will not only provide mobility but also include decoupling qualities.  :thumb:
Robin
Christof
Big Red Machine
oneinthepipe
  • Trainee
« Reply #5 on: 2 Nov 2009, 03:33 pm »
Thanks for the replies.  Does anyone know the thread diameter, pitch, and length of the screws in the spikes?  No one is around to help me place a speaker on the side to remove a spike.
Big Red Machine
« Reply #6 on: 2 Nov 2009, 04:22 pm »
Most likely 1/4-20.  Most of his have been that but no guarantee this one is.
Why aren't you just tipping it over onto a couch cushion or blanket?  Do you have any 1/4-20 bolts laying around you could try and thread into the insert?
Problem with casters is they make your speaker unstable.  And then there's the goofy look. :duh:
jsalk
« Reply #7 on: 2 Nov 2009, 05:53 pm »
On the HT2's, they are 3/8 16.
- Jim
Atlplasma
  • Just off the boat
« Reply #8 on: 2 Nov 2009, 08:26 pm »
Robin
Hi Satfrat:
Are you using the gliders? I have some off-the-shelf units under the spikes on my Songtowers, but they are not super stable. The cone/spike decouplers look like they would certainly be beefier. My current listening room has carpet, but I anticipate that the next place will have wood floors (assuming I can ever find a buyer for my house).  :cry:
