external hard drivee advise
0 Members and 1 Guest are viewing this topic. Read 2033 times.
ecramer
« on: 1 Nov 2009, 01:10 pm »
I need more storage for my desktop looking at an external hard drive 1tb or bigger anybody have any recommendations.
ED
funkmonkey
Re: external hard drivee advise
« Reply #1 on: 1 Nov 2009, 11:18 pm »
I've got two Lacie quadra (http://www.lacie.com/us/products/product.htm?pid=11156) 1TB ea.
one is about a year and a half old the other (back-up) is about 6 months.  The newer version looks exactly the same but runs even more quite.  They both work fine.  I don't use the big blue button, so I have no idea how well this functionality works.  I just liked the way they looked.
I also have another 1TB drive that I built using an (SATA)enclosure ($25) and an internal HD that I already had.  You can put the two pieces together very easily, and it would most likely cost a bit less than buying a pre-assembled external.
zybar
« Reply #2 on: 1 Nov 2009, 11:27 pm »
Ed,
I have had good luck with Seagate external HD's (I have about a dozen of them ranging in size from 200GB to 1.5TB).
They have been very dependable and issue free.
I tend to buy them when they go on sale from Fry's or Newegg.  Both are significantly cheaper than Best Buy, Staples, etc...
George
Nels Ferre
« Reply #3 on: 1 Nov 2009, 11:30 pm »
I've just upgraded from a 500GB Western Digital Elements series to the same drive in 1.5TB size. ($119 at New Egg) and couldn't be happier.
rwdrey
« Reply #4 on: 1 Nov 2009, 11:37 pm »
I've been lucky(knock on wood) with Maxtor One Touch externals. Two 1.5TB, one 1TB, & acouple smaller ones.
satfrat
« Reply #5 on: 1 Nov 2009, 11:41 pm »
I've had 6 Seagate HD's, 40G to 1.5T and haven't had a failure yet. (yet being the key word here  :lol: ) I'm presently using 5 Seagate's in my system and I just upgraded my interior secondary HD to a Seagate 1.5T.
TigerDirect had the best price available and I had no issues with them.  :thumb:
Robin
GHM
« Reply #6 on: 2 Nov 2009, 12:20 am »
I bought a Fantom drive 1 TB through Buy.com for $70.00. Its worked well so far. Looks like their back on sale again! This won't last long http://www.buy.com/prod/fantom-greendrive-1tb-usb-2-0-and-esata-external-hard-drive-2-year/q/loc/101/208503758.html
ecramer
« Reply #7 on: 2 Nov 2009, 12:36 am »
Thast looks like a nice drive with good reviews i snagged one  :thumb:
GHM
« Reply #8 on: 2 Nov 2009, 01:28 am »
Great!! the rebate is solid too. I still have the $20 check that I need to drop off at the bank. :icon_lol:
Once you send in for the rebate, you'll get the check in 4 to 6 weeks.
Well it looks like the sale lasted a day or so. The price is back to normal now..no rebate offered.
« Last Edit: 2 Nov 2009, 03:44 pm by GHM »
