Poll
can i add an an am amplifier to my integrated amp?
yes
0 (0%)
no
0 (0%)
Total Members Voted: 0
specific setup question
0 Members and 1 Guest are viewing this topic. Read 2151 times.
polar316
« on: 1 Nov 2009, 02:38 am »
i have a cambridge audio 340a, can i add a rotel 2 channel power amplifier to improve quality and db's?
mjosef
Re: specific setup question
« Reply #1 on: 1 Nov 2009, 03:24 am »
You can add any power amp once the CA integrated has pre-out RCAs. Does it?
  • Speakers....What Speakers ?
mjosef
« Reply #3 on: 1 Nov 2009, 03:39 am »
Well, looks like it does not have  variable pre outputs, just a line level "Rec-out"...you would need an amp with a volume control.
So your answer is...maybe.  :thumb:
« Reply #4 on: 1 Nov 2009, 12:08 pm »
Without pre-amp outputs from the Cambridge, you'd need to use the "rec-out" and find a power amp with volume controls (fairly rare).
You're other options would be to add volume controls (passive pre-amp, attenuators, or an active pre-amp with another set of interconnects) between the Cambridge and the power amp.
Either way, you're only using the Cambridge as a multiple input (source) selector, so it seems pretty pointless to me.
