0 Members and 1 Guest are viewing this topic. Read 4627 times.
Evaluating a new cartridge has turned out to be not so much fun any more and some fresh input would be helpful. I currently have an AT 120. I like it enough but I need a bit more soundstage and perhaps a bit more musicality.I live in a budget world for audio equipment these days. I have the choices narrowed down to Denon 110DL, AT440Ml or Stanton 681, based primarily on reviews. The Stanton is based on a hunch since I remember them sounding very good in another lifetime. Someone has suggested that I buy used from Audiogon or another serious source. I appreciate the recommendation however I am hesitating on that one. A cartridge is the most fragile of beasts and I just don't want to purchase used. As you can tell my budget is limited. My music tastes are mostly classical, symphony and choral. I have a Denon 500m table with a tube amplifier having a typical mm card. Much appreciated. dk
Hi,The AT-120 is only $79 and is probably tough to beat for that money. I think it really depends on how much you're willing to spend. The Denon 110 and 160 are pretty nice and will probably give you more of that soundstage you're looking for. The AT-440 has a more detailed analytical sound, but I had to load it at 32K to tame the aggressive top end. If you can do that, it's really quite good. I'd take the loading recommendations on that Audiogon thread, with a grain of salt. It's really cartridge and system dependant. Many of those are $300 to $500, if you can find them. If you're in that price range, it's a whole other ballgame. Here's a link to a site where you can download samples, and compare a bunch of different ones;http://myweb.tiscali.co.uk/daveyw/cartridges/Frank
