Poll
Where can I get informations & specifications for Bryston 6B Mono Blocks.
Audio Circle
0 (0%)
Google
0 (0%)
Total Members Voted: 0
Bryston 6B Mono Block Info & Specifications.
0 Members and 1 Guest are viewing this topic. Read 9891 times.
goodattitude88
« on: 31 Oct 2009, 08:44 pm »
I just purchase a pair of Bryston 6B Mono Blocks and I could not find much informations or specifications on Google. Can some one help to provide me a link to get these resources. Thanks.
drummermitchell
Re: Bryston 6B Mono Block Info & Specifications.
« Reply #1 on: 31 Oct 2009, 09:00 pm »
I'd type in bryston limited,there you'll find all the info you need.
Under technical I believe.
Laundrew
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 31 Oct 2009, 09:43 pm »
About 20 years ago we had a mono amp called a 6B which eventually morphed into the first 7B.
james
goodattitude88
« Reply #4 on: 31 Oct 2009, 10:14 pm »
james
James Tanner, is there any chance you can provide me specifications for my Bryston 6B mono blocks as I can't find any in Bryston Technical support web site.
James T
drummermitchell
« Reply #5 on: 31 Oct 2009, 10:28 pm »
HMM.I just checked also and didn't see any either :o.I'm sure James will fix you up.
« Reply #6 on: 31 Oct 2009, 11:14 pm »
james
James T
I will have a look but I do not think I have anything on them - it was before computers!  We built about 50 units and then decided to move that model to a 7B designation with some power supply changes.  The 6B mono was rated at 500 watts per channel at 8 ohms, 800 watts 4 ohms.
james
b5pt9
« Reply #7 on: 31 Oct 2009, 11:30 pm »
You should be pleased to own collector items with top-secret design aa
Ron D
« Reply #9 on: 1 Nov 2009, 07:10 am »
According to an old brochure I have on hand from the 80's the 6B info provided is:
Rated distortion: less than .02% I.M.
or THD from 20-20 KHz at rated power or below.
Rated power:
500 watts 8 ohms
800 watts 4 ohms
500 watts 2 ohms
800 watts 1 ohm
6400 cm2 of heat sinking, etc.
19" X 5.25" X 13.5", 50 lbs.
From the general specifications from all amplifiers:
Noise 100db below full output
Crosstalk - below noise 20 to 20 KHz
Slewing rate greater than 60 volts per microsecond
Power bandwidth less than 1 Hz to over 100 Hz
Damping factor over 500 at 20 Hz, ref. 8 ohms
Gypsy
« Reply #10 on: 18 Apr 2012, 05:49 pm »
Hey guys
I was just curious if someone could give me the value of a Bryston 6B Mono Block
I`ve had one sitting in a rack for many years and have to downsize my gear
It`s in great shape and fully functional
Is it true that there were only 50 of these made as I read in this thread ?
If I`m posting in the wrong area my appologies
Any help or input would be appreciated
