Need Cable sugestions for Dodd pre
0 Members and 1 Guest are viewing this topic. Read 1163 times.
kid coleco
« on: 9 Jan 2004, 12:14 am »
I just recieved the $450 pre from Dodd Audio. Amazing sounding straight ou of the box. Unfortunately my cables connecting my cd player aren't very good and produce a slight hum because of a loose connection. I'm concidering upgrading to DIY bolden cables with bullet plugs. Will these fit securely on the connectors.
Cheers!
Carlman
« Reply #1 on: 9 Jan 2004, 12:18 am »
Good luck.  I've tried Audience, Monster, AR, cheapies, Belden homemade, and just about anything else I can put my hands on and I still get hum.
How loud is your hum?  Do you get 2 kinds of hum or just 1?  I get an idle hum and a volume dependent one.  I've also tried different power cables, a cheater plug (3-2 prong adaptor) and moving the preamp far away from the rest of the system.... all with no luck.  I've even tried mu-metal barriers...
It does sound really good otherwise.  Gary's at CES and I'm waiting to talk to him about the hum.
kid coleco
« Reply #2 on: 9 Jan 2004, 01:20 am »
I here one kind of hum that increseases as volume level increases. When  I touch the cable the hum stops. I tmight be a ground problem.
kid coleco
« Reply #3 on: 9 Jan 2004, 01:47 am »
The hum diminishes when I hold the cable and can only be heard when the volume is turend up.
Cheers!
