BCD-1 remote question
0 Members and 1 Guest are viewing this topic. Read 5183 times.
werd
« on: 28 Oct 2009, 10:46 pm »
Hi folks
I am considering a Bcd purchase and i was wandering if the supplied remote has any usefull functions on my bda-1 and my bp25? I have always have  had  stand alone dacs and have wanted  an all in one player. this is obviousily the only choice considering the rest of my gear. I know this has been asked before but its too hard to pull archive questions.
thanx in advance
drummermitchell
Re: BCD-1 remote question
« Reply #1 on: 28 Oct 2009, 11:23 pm »
Werd,I believe the BCD-1 comes with the BR-2 remote,which will do the pre,dac,
cdp.YOU"LL LIKE THE BCD-1 :thumb:.
YOU COULD LOOK ON THE BRYSON SITE
werd
« Reply #2 on: 28 Oct 2009, 11:27 pm »
Thanx Drummer
drummermitchell
« Reply #3 on: 28 Oct 2009, 11:39 pm »
RATATATTAT.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #4 on: 29 Oct 2009, 12:15 am »
Hi werd
Yes the CD Player now comes with the BR2 remote which will operate all our other products as well.
http://www.bryston.com/BrystonSite05/08/BR2_REL.pdf
james
werd
« Reply #5 on: 29 Oct 2009, 12:19 am »
Hi werd
james
I like that, it makes easier to decide. What is the current wait time on a BCD?
« Reply #6 on: 29 Oct 2009, 12:23 am »
Hi werd
james
Be about 10 days from order depending on colour and size.
james
werd
« Reply #7 on: 29 Oct 2009, 12:28 am »
Hi werd
james
james
Black in 17in model?
« Reply #8 on: 29 Oct 2009, 12:42 am »
Hi werd,
I checked - about a week.
Let me know the dealer if you go ahead and I will fast track it or you
james
werd
« Reply #9 on: 29 Oct 2009, 12:54 am »
Hi werd,
james
thats great thankyou, i will let you know what dealer here in saskatoon i go to...
werd
Laundrew
« Reply #10 on: 29 Oct 2009, 10:20 pm »
Hi werd,
james
werd
Congratulations on the new addition werd :thumb:
Be well...
Viajero5000
« Reply #11 on: 29 Oct 2009, 10:31 pm »
James, would the BR2 work with the BP20?
Viajero5000
« Reply #12 on: 29 Oct 2009, 10:57 pm »
Hi James, when you answer the question above, could you also kindly clarify the following:
1. Can an MPS2 support both a BP26 and a BP20/25 at the same time?
2. The BP20 is identical to the BP25 (except remote) correct?
3. Were any changes made to the BP20 during the course of its production? If yes, what were these, and which year(s) were they made?
The reason I ask is that someone I know is trying to sell a BP20 and I'm toying with the idea of picking it up...
« Reply #13 on: 29 Oct 2009, 11:07 pm »
Hi,
Yes the BR2 will control the older preamps BP25 with an address change.
1. Yes as long as you have the proper connection power cord from the MPS-2 to the BP20.
2. Correct.
3. Minor changes in parts.
james
Viajero5000
« Reply #14 on: 29 Oct 2009, 11:11 pm »
Hi,
2. Correct.
james
Many thanks for the quick reply James. You mention that the BR2 will control the BP25, but will it also work with the BP20 (i.e. 'make' the BP20 into a remote controlled pre-amp?)
Re point 3, did these changes in parts have a material change in the sound quality of the pre-amp?
« Reply #15 on: 29 Oct 2009, 11:14 pm »
No sorry the BP20 can not be made into a BP25 to allow remote control.
The part changes in the Bp20/25 where for production and availablity issues not circuit changes so no differences in sound until the BP26.
james
Viajero5000
« Reply #16 on: 29 Oct 2009, 11:15 pm »
No sorry the BP20 can not be made into a BP25.
james
Thank you James.
werd
« Reply #17 on: 29 Oct 2009, 11:15 pm »
Hi werd,
james
werd
Be well...
Thanx Laundrew, lookin forward to gettin it now.
1ZIP
« Reply #18 on: 29 Oct 2009, 11:35 pm »
Werd;
You will like the BCD-1.  I've had mine about 10 months now and it continues to impress me and anyone that hears it!  I travel a bit, 1 to 2 weeks at a time, each time I return home and crank up the system I'm astounded, just as I was the first time I fired it up
werd
« Reply #19 on: 30 Oct 2009, 10:22 pm »
Werd;
Thanx 1zip, there seems to be no shortage of encouragement for that deck.
