Parasound JC1 vs Plinius SA 250 mk4
0 Members and 1 Guest are viewing this topic. Read 3777 times.
zoltm2001
« on: 28 Oct 2009, 05:25 am »
Fellow inmates,
I wonder if anyone could shed some light on these two amps, Parasound JC1 and Plinius SA 250 mk4. I am probably deciding between these two amps for a driving a pair of MG 3.5
Thx.
Ericus Rex
Re: Parasound JC1 vs Plinius SA 250 mk4
« Reply #1 on: 28 Oct 2009, 12:17 pm »
You're starting off running!  Aintcha!
rydenfan
« Reply #2 on: 28 Oct 2009, 01:53 pm »
I am a big fan of the Plinius sound. They will have more harmonic richness in the mids than the JC1's. They JC1's can be a bit lean depending on the system or they can work very well. I found Plinius to have a very sweet and neutral sound while maintaining good bass control. However, due to their very high gain they can be a bit noisy in some systems.
