My Cornet 'mono-stereo switch' packed it in. What's up with that?
0 Members and 1 Guest are viewing this topic. Read 1297 times.
Bill Epstein
Actually. stereo's fine but when I toggle to Mono, the gain drops off dramatically and sounds like coming from the bottom of a well :?
Maybe I shoulda jumpered this version, too, but I have quite a few really good mono records now.
Maybe one of the board traces is loose?
reuben
Maybe your left and right signals are out of phase. Have you tried reversing the leads on one of them?
Tom
tubesforever
Bill that's weird.  In my C2 the mono sound a little more grounded in sonics and the stereo sounds a little more thin and airey.
I hope you find what's reversing your reality!  A parallel universe?  ;-)
Best of luck working the problem Bill!
Bill Epstein
Tubes, as usual, you're right about the parallel universe:lol:
When i reversed the leads to the Cinemags, the mono came back but the stereo went out, or was it TOWA? :duh:
It gets better! When I switched from the SME with a grounding wire to the Cherry arm (no metal, no ground) the Cinemags went from silent to HMMMMMM! However......if I push down on the armboard slightly, the humm diminishes by about 80%
