**SOLD** Emotiva XPA-3
0 Members and 1 Guest are viewing this topic. Read 2686 times.
Big Red Machine
« on: 27 Oct 2009, 12:17 pm »
How about $450 + shipping in original box.  Approx. 2-3 months young.  Sale at Emotiva right now so this is tight.
Number of Channels: 3
Topology: Fully Discrete, Dual Differential, High Current, Short Signal Path Class A/B
Power output (all channels driven):
300 watts RMS @ 4 ohm (0.1% THD)
200 watts RMS @ 8 ohm (0.1% THD)
Power Band Response:  20 Hz to 20 KHz with less than .05db deviation at rated power
Broadband Frequency Response (-3db), referenced to 1/8 power: 5 Hz to 150 KHz
Amplifier Gain:  32db
Signal to Noise Ratio (S/N) (20KHz bandwidth, A-weighting), referenced to full output: 112db
Input Impedance:
Unbalanced - 47KOhms
Balanced - 51KOhms
Transformer Size:  850VA
? Fully protected from all fault conditions
? Soft start circuitry
? External trigger turn on
? Soft touch power switch
? 5RU chassis w/ solid milled aluminum faceplate
? IEC power inlet, 120/230 VAC configurable
? Output design: Triple Darlington with On output stages
? Differential Drive: Dual Differential input
? Types of inputs: Balanced (XLR) and Un-balanced (RCA)
? Type of outputs: Audiophile quality 5 way binding post
? Display type: Digital status indicators
? 17? W x 7.75? H x 19? D
? Weight - 57 lbs (72 lbs boxed)
* Specifications subject to change without notice.
Additional notes: Glass epoxy pc boards, 1% resistors, metal film capacitors, soft start circuitry (does not have a current spike on start up).
Modular channel design for greater channel separation, auto rail detection relays for automatic voltage selection. The unit also has switches for turning the metering and/or the status LED's on or off.
« Last Edit: 11 Dec 2009, 11:27 pm by Big Red Machine »
Mudslide
Re: Feeler: Emotiva XPA-3
« Reply #1 on: 27 Oct 2009, 01:18 pm »
PM sent.
Big Red Machine
Re: Emotiva XPA-3
« Reply #2 on: 29 Oct 2009, 02:08 am »
Bump, for sale.
polar316
Re: Emotiva XPA-3
« Reply #3 on: 1 Nov 2009, 02:17 am »
bump... whats the new price?
Big Red Machine
Re: Emotiva XPA-3
« Reply #4 on: 1 Nov 2009, 11:39 am »
Price hasn't changed.
Big Red Machine
Re: Emotiva XPA-3
« Reply #5 on: 3 Nov 2009, 01:48 pm »
bump
cliffy
Re: Emotiva XPA-3
« Reply #6 on: 3 Nov 2009, 08:50 pm »
Where is the product shipping from?
Big Red Machine
Re: Emotiva XPA-3
« Reply #7 on: 3 Nov 2009, 08:57 pm »
48188
Big Red Machine
Re: Emotiva XPA-3
« Reply #8 on: 6 Nov 2009, 03:15 pm »
bump
Big Red Machine
Re: Emotiva XPA-3
« Reply #9 on: 9 Nov 2009, 02:19 pm »
bump
Big Red Machine
Re: Emotiva XPA-3
« Reply #10 on: 2 Dec 2009, 02:51 pm »
Still for sale and on Audiogon
Big Red Machine
Re: Emotiva XPA-3
« Reply #11 on: 8 Dec 2009, 12:28 pm »
bump, split shipping
