OHM speakers with AVA gear?
0 Members and 1 Guest are viewing this topic. Read 9239 times.
robinje
« on: 26 Oct 2009, 09:20 pm »
Is anyone here running their AVA gear through OHM speakers?  The newly revised speaker lineup looks pretty nice and the cost is reasonable, along with a generous money back in-home trial period.  I was aware of this brand back in the 70's/80's, but had forgotten about them until very recently.  The design certainly is unique, as far as I'm aware.  I've always had multi-driver "standard" speakers with crossovers, but the latest OHM-Walsh single driver with "super tweeter" intrigues me.  I'd appreciate any first hand experience with these speakers, particularly with AVA amps if possible.  Thanks!   aa
charmerci
Re: OHM speakers with AVA gear?
« Reply #1 on: 26 Oct 2009, 09:42 pm »
(Please excuse this temporary highjack of this thread.)
OMG! You just took me back 28 years!  :lol: Someone I knew had a pair of OHM F's.  It was so long ago I can't even recall if I thought they were good or not. :icon_lol: (And no, I'm not going senile. aa)
I didn't even know that they still existed.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 26 Oct 2009, 10:03 pm »
http://ohmspeakers.com/
Listens2tubes
« Reply #3 on: 26 Oct 2009, 11:15 pm »
I still have my Ohm L speakers. They last did duty in my photo darkroom. That was until we moved into this house in 1992. As I fondly remember they were a bit bright with beautiful midrange hooked up to my Onkio SS receiver. A friend still uses his Ohm I's. With their multi angle drivers they were very open sounding. :oops: Remember when anything good was clean and open sounding. :lol:
I did also run across their wesite awhile back. Good to know drivers are still available. Figure the L's next duty will be in one of my kids first decent system. :thumb:
S Clark
« Reply #4 on: 26 Oct 2009, 11:23 pm »
Way back in 1976 I looked at getting a pair of Ohm F's and went with the Design Acoustics D-12 instead.  I just didn't have enough amp to drive the Ohms, which were very power hungry in those days.  The old D-12's still hold up pretty well on large orchestral music.
Brett Buck
« Reply #5 on: 27 Oct 2009, 04:25 am »
   I have Ohm Walsh II's with the Walsh 100 Mk2 "upgrade". Really, it' s not an upgrade, any more than an AVA Omega 170 is a "upgraded" ST-120.  All the active parts are replaced, the only thing left are the cabinets.
     The imaging and sound field is fantastic. The extension of the bass, with the new drivers and the port tuned to a lower frequency, is absolutely startling - very much deeper, very much tighter, tremendous performance for the size. The high end is pretty good, not nearly as clean or high as the B&W's I have, but very good. The tweeter dispersion is not very good by comparison to other amps, particularly the B&Ws with the separate free-floating "teardrop" enclosure A very good  improvement on both ends compared to the original Walsh II.
    What is not as good, and was not an improvement on the original Walsh II, was the midrange. The ends seemed tipped up pretty significantly compared to the middle. It was clean enough, but it was rolled off in the middle to the point that it was noticable. I ran mine just about every day for a year and a half, and it got a lot better, but not "flat" response. At least not yet - one thing that was clearly obvious was that it was changing very rapidly and drastically towards a flat response as it mechanically loosened up. When I first modified it, I was very disappointed in the change, because it sounded like I had thrown a towel over the drivers. Over the course of a few hours, it got a lot better but dear God, it was still changing 6 months later, and never stopped in the year and a half I ran them. The entire time, the midrange was coming up, and it was getting close at the end. But it only took a quick comparison to the B&W's I have (DM110, DM602, and 803S) to hear it still wasn't there. As I had way more speakers than I could use, I loaned the Walshs to my friend for his second system. Last time I was up there, they were still closer but still not done changing. I may not have run them hard enough to get everything working and loosened up, but I eventually just got tired of waiting. So there is good and bad. They are very competent speakers, and even the dinky little Walsh 100s have really unbelievable bass extension and punch in appropriate rooms. They aren't kidding when they say you don't need a subwoofer.
     The service it absolutely top-notch. On the topic of subwoofers, I also had an old Ohm N2 subwoofer than the same friend took to run with his teeny little main speakers.  I had never had much luck with the subwoofer with my original Walsh IIs - all it did was make the same bass frequencies louder, it really couldn't play significantly lower than the main speakers. I tried high-power rheostats in the input line, and also changing poles in the crossover to lower frequencies, without much luck.  I futzed around trying to adjust the relative output, and ended up thinking everything was best with the sub turned all the way down, or disconnected entirely.
   When I got the upgrade, it was clear I didn't need any more extension and the subwoofer was completely superfluous so it just stayed in the closet. Once my buddy started using them, they were clearly helping. although nothing to write home about.   But the drivers had foam surrounds, and after sitting in my closet for ~25 years, and playing at his house for a few weeks, they just fell apart. We called Ohm, and got the president of the company (John Strobheim?). They had replacement drivers for a reasonable price, but we also mentioned the initial experience with not enough extension and the various mods I had made to reduce the output. He suggested putting the wiring back to stock, and instead retuning the enclosure to a lower frequency with a lower cutoff. He even made some inserts to put in the bass reflex ports - no charge. We changed the drivers (which were of much higher quality than the originals), and yeah, it worked OK, more or less, but still not impressive and had way too much overlap with the mains just as I had found in 1985. Then we put the inserts in the ports and it was absolutely incredible!  Very much deeper frequency response, and very little output WRT the main speakers. Nothing seemed overdone anymore, overall very nice balance, and exceptional bass (maybe not "thundering" with the cheesy Arcam integrated amp but very solid). That the company president was willing and able to dramatically improve a product that they haven't made in 25 years and he probably had never seen before, just from phone conversations, was far above and beyond my expectations. Good people there at Ohm.
   The prices are excellent for the quality. These are top-notch high-end speakers - no compromise type items. They won't try to upsell anything - they want to know your room volume, select the model based on that, and that's all you need. A lot like dealing with Frank - who will also try to give you what you need. If you only need 120 watts/channel, that's what he will recommend.
    I ended up not finding them perfect (hate to break it to anyone, but there's no such thing as a perfect speaker) but certainly good enough to keep around instead of returning. They didn't quite out-do the B&W 803S in my main system but the B&W's cost 4-5x as much even with a "deal".
  So, you really can't lose. Get them, try them out, and return them if you don't like it.
    Brett
rcag_ils
« Reply #6 on: 27 Oct 2009, 02:41 pm »
Brett Buck
Could you tell me if your Walsh II has the castors for feet, or  small wooden blocks.
Brett Buck
« Reply #7 on: 27 Oct 2009, 02:52 pm »
     Little wooden blocks, about 1 1/4" square and about 2 1/2" high. I think the casters are on the very recent models - my Walsh IIs enclosures are from 1984.
     Brett
rcag_ils
« Reply #8 on: 27 Oct 2009, 04:21 pm »
I have a pair of Walsh IIIs from 1991 (that's what the dealer wrote on their store tag), I can never figure out how to set the switches at the bottom.
Anyway, they came with casters for feet. I think they sound a tad too bright for my taste, but the worst of all, the bass seems to be a bit weak for the cabinet of that size. I took the speaker modules off, and the speakers look new. I suspect the casters may be the cause of it, since I am not sure if they came like that or the previous owner put them on.
They haven't been played for years, just sitting there taking up space.
Wayner
« Reply #9 on: 27 Oct 2009, 04:37 pm »
Oh yes, the Ohm speakers with the Walsh driver, Is it like 1972 over again? I never got to hear these speakers, but they always seemed to get a heads up review by Stereo Review or High Fidelity magazines. Oops, I think I dated myself again.
Now here is the dumb question for this this thread. Was the Walsh driver an early composite of what we would consider to be a ribbon tweeter? And wasn't it also supposed to be omni-directional? Old brain cells forced to think.....aarrg.
Wayner
turkey
« Reply #10 on: 27 Oct 2009, 04:44 pm »
John Strohbeen seems to be a really nice guy, and he knows his products really well. I've also heard that Ohm offers really good service.
I heard the Fs years ago, then some of the models like the 1, 2, 3, 4, etc. later on, and more recently a pair of 300s that had been upgraded.
They do some things well, but ultimately they don't sound quite right to me. I know the newer models are not fully omni-directional, but they share the same faults I have heard with other omni speakers. They seem to add ambiance to all recordings, and they seem very fussy about the room and positioning within the room.
I also found the bass to be kind of "lumpy" pretty much across the board.
If you find you like the presentation the Walsh drivers give, you might also want to check out some of the Mirage Omnipolar speakers. They throw a similar soundstage, but they're easier to place within most rooms.
I've found that I like speakers that offer more controlled directivity than these do. YMMV. :)
  • Speakers....What Speakers ?
« Reply #11 on: 27 Oct 2009, 04:45 pm »
From....way back when...the older Ohm speakers always needed a lot of power.... :rock:
Here's some info....... :thumb:
turkey
« Reply #12 on: 27 Oct 2009, 04:47 pm »
Wayner
No, it was just a cone with the voice coil at the apex, like any other cone driver. The difference is that it's placed with the voice coil at the top, and the sound that reaches your ears is produced from the opposite side of the cone than what is normal for a cone driver.
It's like one of those orange traffic cones with a voice coil mounted on top so that the cone moves up and down.
bummrush
« Reply #13 on: 27 Oct 2009, 04:54 pm »
 The line they have out now looks nice,would love to hear those small ones.
charmerci
« Reply #14 on: 27 Oct 2009, 04:58 pm »
Wayner,
Since you have a terrible cold/flu (MY BRAIN HURTS!!!), this article has a cut-a-way view of the OHM speakers - with super tweeter on top.
http://6moons.com/audioreviews/walsh/micro.html
Brett Buck
« Reply #15 on: 27 Oct 2009, 07:02 pm »
  The current versions are reasonable compared to the Fs. I think the upgrade versions I have are 85-86 db/watt, and I can assure you that they get loud enough with a 30 wpc amplifier.
    Brett
Brett Buck
« Reply #16 on: 27 Oct 2009, 07:11 pm »
   In the middle position, as I recall.
  Based on my experience, I would bet a fair bit of money that the current upgrade drivers and probably port inserts will likely solve any weak bass problem!    I am not sure what problem the casters might be causing - the driving forces are up and down, not side-to-side, so I wouldn't think there would be much issue with the casters permitting a lot of movement.
    My 1985-era Walsh 2s, pre-upgrade, were nothing to write home about when it came to bass extension, and the Walsh 4's I heard in that era were not very impressive, either, for as big as they were. Post upgrade, there's little to complain about in "depth of bass" on the Walsh 2 - it was a startling improvement, almost to the point of unbelievable.
     Brett
Wayner
« Reply #17 on: 27 Oct 2009, 07:30 pm »
Wayner,
Thanks charmerci, now I remember the tweeter driver element. Yeah, their goal was to be omni-directional, but heck, put my Dynaco A25XLs in the right position and they are 3 dimensional. I'd still like to hear a pair.
Wayner
rcag_ils
« Reply #18 on: 27 Oct 2009, 09:07 pm »
Ohm Walsh concept never worked well, their speakers didn't sound that good then, but I don't know about now. There are many ways to archieve the 3 dimensional sound stage, putting the speaker facing down, and relying on the back side of the cone to cover the whole audio band just not moving enough air in my opionion.
The Design Acoustics point source sound much better, I am currently restoring a pair of PS-10, can't wait to get them done.
Brett Buck
« Reply #19 on: 28 Oct 2009, 03:33 am »
   But, there aren't a lot of good ways to maintain phase information. I think you are missing the key feature. specifically, that it doesn't count on the driver working like a piston (which it, for the most part, it doesn't, whether intended to or not), in fact, it counts on the wave travelling down the driver from the voice coil end to the suspension end at a finite rate. The angle of the cone is intended to balance the speed of the wave down the cone with the speed of sound in air so that any compression wave leaving from the little end is in phase with the same wave when it leaves the big end. Hence the three cones of different angles in the OHM A, and the three-piece cone made of 3 different materials on the OHM F. It's not as simple an plunking a generic driver like any other on top of a hollow box in a funny orientation, instead of hoping it acts like a rigid piston, it counts on the cone being flexible in just the right way. It's essentially impossible to make a single driver that is sufficiently rigid to act like a piston at 15 Khz and still be able to move enough to play bass. That's why you have 3 or so drivers and crossover networks in conventional speakers. In fact B&W is making tweeters out of diamonds to try to get them to move like pistons at 20 khz.
    Of course it could be debated how well it works in any particular case, and the approach has some interesting side effects,  but the basic idea is an order of magnitude more sophisticated than conventional speakers. I'm no Ohm cheerleader  - I have B&W's for both my current systems - but there's a lot more to it than you suggest.
     Brett
