SOLD: Tact 2.0S AAA Room Correction Preamp w/ full Aberdeen/Maui Mods
0 Members and 1 Guest are viewing this topic. Read 1931 times.
mdconnelly
For sale: Tact 2.0S AAA Room Correction Preamp with complete mods by Anthony Padilla/MauiMods including both ADC and DAC fully-Aberdeen-modded boards.  According to Anthony, the full mods alone on this unit run $2400 now.
PRICE DROP!!!   Need to sell - Will sell for $3400 $2800 $2500 + shipping and paypal!
If you know what the Tact room correction preamp is capable of and are familiar with Anthony Padilla at MauiMods/Aberdeen, then you already know how good this preamp is.  If not, read on...
If you need..
- an exceptional DAC capable of handling hi-res digital input and upsampling to 24/192
- a preamp capable of digital output
- a highly flexible preamp capable of handling both analog and digital sources
- a preamp with the ability to handle a myriad of RCA, BNC, XLR and optical input/outputs with easy and remote-
enabled switching between sources
- a highly resolving room correction system capable of easily comparing nine different response curves + bypass that you can fully manipulate via your own computer
- full parametric equalization
or any combination of the above, then read on...
The Tact 2.0S has been exceptionally reviewed as great performer on its own.  Designed for two-channel stereo, its room correction, flexibility and operation in the digital domain are phenomenal.
This preamp has a highly modded DAC card for analog output. It also has the latest 2.0S motherboard with the following digital inputs: 2 RCA-coax, 1 BNC-coax, 1 XLR, and 1 optical.   In addition, I added a fully modded  analog-to-digital card a year ago for vinyl playback that also benefits from room correction.  I was blown away by how good analog playback is with this unit!
Also included is a replacement AudioControl microphone, which is included at the asking price. (Cost ~$150) The new mic measures the room more accurately than the stock one and therefore provides even better correction.
You can find the myriad of features of this preamp in numerous glowing reviews, but to summarize...
-- Full room correction across the 20hz to 20khz spectrum
-- 10 memory slots for storing 9 different correction curves plus bypass.
-- 10 band per channel parametric EQ
-- 5 digital inputs (2 RCA, 1 BNC, 1 XLR, 1 optical) accepts up to 192khz / 24bit
-- 4 stereo analog inputs (3 RCA pair and 1 XLR balanced pair)
-- 3 digital outputs (1 RCA, 1 XLR, 1 optical) up to 192khz / 24bit
-- 2 stereo analog outputs (1 RCA pair, 1 XLR balanced pair)
The room correction is simply amazing.  Plug in the mic, connect your PC via the supplied cable, run the supplied software and it will measure room frequency response and calculate appropriate response curves based on 9 different target curves - either supplied or drawn by you.  If you have a room that you suspect is causing concerns, you will be blown away by what this preamp can do.
As good as the stock 2.0S is, the full mods by Anthony at Aberdeen/MauiMods take this unit to a new level of detail, clarity and extended resolution!   Anthony, who has the midas touch when it comes to such mods, has applied every possible improvement to this unit. Details of all his mods can be found at http://mauimods.com/TacTAudio.htm.  Mods on this unit include:
--Complete motherboard mods for 2.OS
--Replacement of op amps and all capacitors with Sanyo Oscons
--Digital output board mods: Replacement of pulse transformers using Scientific Conversions SC947-02 transformers
--Aberdeen Signature complete drop in power supply
--Aberdeen ultra high performance IDE and power cables
--Aberdeen Analog input board mods
--Aberdeen Analog output board mods
Note that Anthony's mods carry a lifetime warranty so if you have any concerns, Anthony will take care of it.
This is the fully black version and condition of the unit is excellent.  I'd rate it 9/10 simply because it's 3 years old but appearance is still as new.  Shipped in original double-box Tact packaging and including Tact and AudioControl mics & cables, remote control, Tact 2.0S software, and cable to connect to your PC.
This preamp takes you immediately to the very best that the Tact 2.0s can achieve and that is something totally special.  PRAT, resolution, transparency & razor sharp imaging are simply just amazing.
« Last Edit: 5 Dec 2009, 02:33 pm by mdconnelly »
mdconnelly
Bump with a big price drop!  Will sell for $2800 or best offer.
mdconnelly
Bump!  Another price drop!  Will now sell for $2700 + shipping and paypal!
mdconnelly
Gotta find a home for this wonderful preamp/DAC...
Will now sell for $2500 + shipping and paypal!
mdconnelly
