Love the Ultrasonic Tube Dampers.
0 Members and 1 Guest are viewing this topic. Read 8248 times.
Lizard_King
  • Tubes Rule!
« on: 25 Oct 2009, 04:56 pm »
Steve,
     I have been using your dampers on my output tubes, Output stage in my Dac and Power supply in my Dac. I feel these dampers make the sound more organic and natural.. That translates to a more musical experience.
      I have ordered 7 more dampers so every tube in my system will benefit from your dampening.
      Keep up the great work.
Liz
« Last Edit: 12 Dec 2009, 03:33 pm by Lizard_King »
Herbie
    • Herbie's Audio Lab
Re: Love the Ultrasonic Tube Dampers.
« Reply #1 on: 25 Oct 2009, 05:40 pm »
Thanks for the post, Liz.
Steve :D
Herbie's Audio Lab
« Last Edit: 23 Aug 2010, 01:23 am by Herbie »
rollo
  • Rollo Audio Consulting -
« Reply #2 on: 10 Dec 2009, 04:07 pm »
Took the plunge bought 6. Excellent service, order processed same day shipped next. Gotta love it. Now if the dampers perform as advertised BRILLIANT. Let ya know the outcome.
charles
rollo
« Reply #3 on: 23 Dec 2009, 07:47 pm »
Well well well. An improvement in clarity and focus, maybe softened  the top a tad but the jury is still out on that.
charles
zybar
« Reply #4 on: 23 Dec 2009, 09:37 pm »
I use 10 Ultrasonic Rx for the 6SN7's in my Atma-Sphere MA-1's and three more for the tubes in my Modwright Transporter.  In both cases I felt that there was a level of improvement and that it was well worth the cost.
You don't have to take my word on how good they are, order some for your system and let YOUR EARS decide.  If you don't hear a difference or think they are worth the investment, send them back to Steve for a full refund.
Trying and deciding is always the best approach.
Enjoy.
George
satfrat
« Reply #5 on: 24 Dec 2009, 12:14 am »
On the stereo 6SL7GT tubes of my Butler 3150, I just replaced Herbies original Hal-O's with his Ultrasonic Rx rings. Still too early to really have any thoughts on what if any improvements I might get from these specialty dampeners over the Hal-O's but I'll keep them regardless and I'll try to give away the original Hal-O's to another Butler owner.(hint?) For this tweaker, any minute gain of my Butler's performance is worth the effort and I did like what the original Hal-O's offered in the way of clarity. Any additional smoothing out would be sweet indeed.  8)
Robin
jtwrace
    • TIPP YouTube Channel
« Reply #6 on: 24 Dec 2009, 12:33 am »
Steve,
Can you explain how the different "flavor" rings will affect the sonic signature?
I'll be looking for some for 7308's.
Thanks.
Herbie
« Reply #7 on: 24 Dec 2009, 02:14 am »
UltraSonic Damping Instruments affect a system's sonic signature mostly by helping to reduce the system's sonic signature and bring out a more faithful rendering of the musical event.
UltraSonics are the current generation in a linear progression of damping instruments of which each design has improved upon the previous. Some improvements have been sonic, some functional, some a combination of both. UltraSonic Damping Instruments have achieved a degree of perfection that overcomes any of the particular drawbacks of earlier designs.
The "flavor" you refer to is more along the lines of subtle differences in dynamic and microdynamic resolution and impact; all are quite linear with frequency response. The descriptions on our website are straightforward; you don't really need to try to read anything into them.
7308s are typically extremely sensitive to micro-vibrations; likewise, they are extremely sensitive to microdynamic nuance and subtlety in the music that is often somewhat masked by micro-vibrations. I recommend Preamp UltraSonics or UltraSonic Rx to bring out the very best in these tubes, though any of Herbie's damping instruments do very well with virtually all 6922-type tubes including 7308.
Differences between the various damping instruments are difficult to explain and differences will vary between different tubes, components and systems. Here is a brief overview, though:
Teflon HAL-O: Herbie's first product that introduced Herbie's Audio Lab to the audiophile world was for several years our reference product. HAL-Os have no particular sonic drawback with small-signal tubes and are overall very linear and do a great job of reducing microphonic distortion. They're fast dynamically, but compared to lickety-split UltraSonics, can seem dull in comparison. The major drawback with Teflon HAL-Os is their use will larger and hotter-running tubes--they don't maintain as well of a grip under extreme heat and the silicone isolation pads sometimes don't hold up over the years with extremely hot-running rectifier and power tubes.
MidFi+ Damping Instruments do have a slight "flavor" to them, tending to induce a subtle, gently-rising deep bottom end. It's not bloopy or anything and seems very linear. Though named "MidFi," they're really quite hi-fi. For tubes that aren't overly microphonic, they're a great bargain and provide a listening experience overall just about as enjoyable as any.
PEEK Damping Instruments tend to emphasize dynamic impact in music that is dynamic. With subtle music, the subtleties come through. PEEKs have more of a unique characteristic of being more sensitive to placement on the tube, and thus lend themselves somewhat to "tuning" by adjusting their placement. They are sometimes a little "slow" with microdynamics compared to UltraSonics, and the material cost makes them somewhat cost-prohibitive compared to UltraSonics. They are presently sold basically "at cost" to recover material investment.
BlackBery HAL-Os have no particular advantage over Preamp UltraSonics, which will ultimately replace BlackBerys in the product lineup. Sonically, BlackBerys are sort of picky about the component they're used in--they do beautifully, almost magically, in some preamps, CD players, Hammond organs, tube microphones, and other components. In others, they do relatively poorly.
Standard UltraSonics are our basic default recommendation for all vacuum tubes. They're very neutral sonically, very revealing of the source.
For small-signal tubes, Herbie's new Preamp UltraSonics tend to deliver a sonic presentation equivalent to standard UltraSonics, with a little more capacity to overcome microphonics. In some systems, they'll give a little less harsh of a result than standard UltraSonics.
Guitar Amp UltraSonics are designed to overcome vibrational torture chambers like combo guitar amps. They do the job very well, yet perform amazingly well in home audio systems, also. Every bit as engaging and musical as standard UltraSonics, they sometimes tend to provide a slightly more sense of "air" to the music.
UltraSonic Rx is overall our best damping instrument. If they were not more expensive than standard UltraSonics, Rx would replace standard UltraSonics in our lineup. Claiming they are our "best" is based on personal listening experiences. Several customers have auditioned Rx and standard UltraSonics, and in every case the Rx version prevailed. Differences between them are quite subtle though, and sometimes not readily apparent with quick A/B comparison. A more readily apparent difference occurs with systems that tend to be overly "dry." Not necessarily "analytical" but artificial-sounding as opposed to being organic and fluid. Rx Damping Instruments tend to cure this, thus the name, "Rx."
Preamp UltraSonics, Herbie's newest product, is an attempt to achieve the musicality of Rx with small-signal tubes at a more affordable price. I believe we have accomplished that goal, though Rx still provides just a tad more of a "there" there that I can't quite put my finger on or articulate just with words.
Herbie's Audio Lab
jtwrace
« Reply #8 on: 24 Dec 2009, 03:04 am »
Steve,
Thanks for that.  I'll be ordering some...
