Valvo Philips EL60 (EL34) NOS Quads. Simply the best EL34
0 Members and 1 Guest are viewing this topic. Read 9242 times.
nurxhunter
ULTRA RARE EL60--Earliest Version of Holland EL34
Current Matched 29 mA +/-1.3 CV% = 4% @ 400V Average (n =8)
the deviation within an octet is 2 mA or less!
Data from Calibrated (in March 2009 by R. Kennedy) Hickok TV-10A/U:
gM = 6750 +/-250 (CV% = 4%) for all eight tubes!!  Min is 3800.
On an EICO 666 with NOS at 100%, these test 105% +/-3 across an octet.
http://www.audiogon.com/cgi-bin/cls.pl?accstube&1267460852&/Valvo-EL60-Daddy-of-EL34-Plug-
Please see Agon ad.  $850 per quad, I have three quads available.
These are constructed to the military spec., insofar as:
1) support rods clamping the mica and dampening the tube to vibration and microphonics.
2) Rounded plates to dissipate heat.
3) Metal loctal base.
4) Pins connected directly to electrodes
5) Solid disc getter, signifying the earliest EL34 made in Holland
6) What appears as very active barium to absorb impurities from the vacuum by virtue that the tops of the tubes darken quickly, which is a good thing, I have read.
7) Ceramic spacers clamping the micas.
8) Remarkable construction for an EL34.
These are EL34--only with a loctal base.  High quality loctal-to-octal adapters are provided.
In the RM9 MK2, these sounded quite remarkable.
True-tested NOS.  Current matced at high voltage.  gM matched.  Emission matched.  Tested in a refined, high power amplifier.  See the Agon link.  Here is a link to read a bit more.
http://digilander.libero.it/pasqua49/Guide%20to%20the%20EL34/guide%20to%20EL34%206CA7.htm
See link below for a nice picture of construction.
http://www.radiomuseum.org/tubes/tube_el60.html
I guarantee compatibility with the EL34 and no issues--and--reproducible data.  The included adapters are EXCELLENT QUALITY.
My feedback on Agon, Ebay and HeadFi is under this same name.
SUMMARY EL60
Base      Loctal-9-Pin (B9G) (Codex=Ya)
Filament    Vf 6.3 Volts / If: 1.3 Ampere / -: Parallel, (AC/DC)
Description    Power output pentode, launched mid 1948 by Philips
Many years after the F443N the EL60 appeared as a new 25 W power output pentode, now as all-glass tube with the 9-pin "key"(Loktal)-base as the EF50. As this wasn't accepted by the market, one year later it became provided with an octal base and appeared then as EL34, which is in production up to today. [Jacob Rosch?,15 May 2003]
« Last Edit: 2 Jan 2010, 05:26 pm by nurxhunter »
Ericus Rex
Re: Valvo Philips EL60 (EL34) NOS Quads. Simply the best EL34
« Reply #1 on: 25 Oct 2009, 09:08 pm »
YOWSA!!!!
nurxhunter
Search EL34 metal base and you will see that early on, Philips integrated adapters on their EL60 and called them EL34!  TRUE metal base.  The later metal base EL34 are only thin metal collars for show.
The EL60 for sale might be the finest (construction and sonics) EL34 ever made.  Se my feedback on agon, ebay and headfi.
Matched quads--NOS (NEW old stock) available.
Offers welcomed to audiophiles with upstanding feedback.
nurxhunter
Re: Valvo Philips EL60 (EL34) NOS Quads. Super EL34
« Reply #3 on: 12 Dec 2009, 09:27 pm »
Consider these as early 'big feet' EL34.
EL60 including high quality adapters.
I love early Holland DDs and UK OOs.  These are significantly better.
HH+HNY
« Last Edit: 24 Dec 2009, 10:04 pm by nurxhunter »
nurxhunter
Re: Valvo Philips EL60 (EL34) NOS Quads. Now $850.
« Reply #4 on: 24 Dec 2009, 10:04 pm »
Now $850.
HH+HNY
nurxhunter
Slightly updated ad.  Thanks.
zenbonsakura
« Reply #6 on: 21 Jan 2011, 03:11 pm »
If you still have them I would like to give these quads a try.  PM me for payment details  :thumb:
