Mcintosh MC2200, 200W Power Amp
0 Members and 1 Guest are viewing this topic. Read 6516 times.
waamamps
    • WaamampS
« on: 24 Oct 2009, 08:26 pm »
Mcintosh MC2200, 200W per channel in good condition considering its age. Amp has some scratches and rust. This Mcintosh MC2200 amp is all original with the exception of the power knob.
Mcintosh MC2200 has been fully bench tested and serviced.  All switches and controls have been cleaned and lubricated, there is no noise or static in any of the controls. All indicator lights were replaced and are working perfectly, and fully functional. All inputs, outputs and functions are fully bench tested and working perfectly. All loose, cold-solder joints especially on the input / output jacks. Pots and switches have been de-soldered and re-soldered. Amp bridge rectifier and all output transistors were removed cleaned of the old zinc oxide and new heat sink compound was re-applied. Protected relay was removed, cleaned and lubricated. Amp has no power supply hum of any kind. Unit is dead silent when no input is present. Amp has an excellent safe, AC power cord. Amp is in excellent working condition. More pictures are available upon request.
Asking $899
email: [email protected]
Jason Brent
Re: Mcintosh MC2200, 200W Power Amp
« Reply #1 on: 24 Oct 2009, 09:51 pm »
Edit:  found the answer once I re-read.
