Pairing Integrated amplifiers with Emerald physics CS3
0 Members and 1 Guest are viewing this topic. Read 4279 times.
sailender
HI
How to pair Integrated amplifiers with Emerald physics CS3?
I do not know how a conventional  integrated amp can be connected to Behringer DCX2496.
Help needed
Sailender
sfdoddsy
Re: Pairing Integrated amplifiers with Emerald physics CS3
« Reply #1 on: 25 Oct 2009, 09:27 pm »
Normally they can't be. It need to go between a preamp and the power amp.
Clayton
« Reply #2 on: 25 Oct 2009, 09:59 pm »
Hi Sailender,
The DCX2496 can be used in the tape loop of your integrated amp, if it has one. Many current integrated amps do not feature a tape loop.
Clayton Shaw
President | Emerald Physics
sailender
« Reply #3 on: 26 Oct 2009, 02:57 am »
Thank you for the info.
I have sent a Private message to you.Please Check it Sir.
sailender
« Reply #4 on: 11 Nov 2009, 11:52 am »
Solution given by zybar on: 7 Nov 2009, 12:01 PM
"Your source goes into the DCX and the output of the DCX goes into the RWA integrated.  Basically treating the RWA as a power amp.
Depending on the cables being used, you might xlr adapters as I don't believe the RWA gear has balanced connections.'
Solution given by Raindrop audio Singapore for Marantz SA11S1 CD Player +Signature 30.2 integrated
"The output of the the Marantz SA11S1 CD Player is 5V RMS balanced, high enough to go directly into the crossover without needing gain from a pre-amp. The output from the crossover can go into the Signature 30.2 integrated which is a great match with the CS3. This setup is very cost effective. However one cannot add other sources."
sailender
« Reply #5 on: 11 Nov 2009, 12:10 pm »
I have recently ordered Emerald Physics CS3.
Need members help in identifying cost effective pre/power amp set up for these speakers.
Nyal Mellor
  • Founder - Acoustic Frontiers.
    • Acoustic Frontiers
« Reply #6 on: 24 Nov 2009, 10:56 pm »
ATI? 4 channel 1804 at $1800 or so? http://www.ati-amp.com/at1800.html
