Finished Piccolo board dimemsions?
0 Members and 1 Guest are viewing this topic. Read 1284 times.
JimK
« on: 23 Oct 2009, 06:17 pm »
Does anyone have the dimensions of a completed Piccolo PC board, and if so, would you be willing to share them with me, please? My parts are on order, and I'm wondering if a completed board would fit into a "1U" height (1.72" OD), 1/4-rack (4.18" OD width) Lansing "B" box, 6" deep:
http://www.lansing-enclosures.com/main/graybox/b-style/sizes.html
I'd hate to buy the box only to find the board doesn't fit...
Thanks all!
Jim
hagtech
    • http://www.hagtech.com
Re: Finished Piccolo board dimemsions?
« Reply #1 on: 24 Oct 2009, 08:27 pm »
PICCOLO is 3 x 5 inches.  Height is under an inch, if you don't count the switch shafts and leave off the battery connector.
jh
JimK
« Reply #2 on: 26 Oct 2009, 01:36 pm »
Thanks! It appears that this would be a very tight fit, and/or possibly "un-doable" due to the top mounting flange of this box intruding into the width dimension....
Much appreciated!
Jim
tubesforever
« Reply #3 on: 1 Nov 2009, 07:16 am »
I have found it easier and better to have a larger box with extra room for any future alterations.
The Piccolo is so good that if built right  it will be a lifetime item in your system.  Jim I hope your build goes smoothly.
Cheers!
