0 Members and 1 Guest are viewing this topic. Read 33030 times.
IKEA Lack side table with adjustable screw in points in the bottom of each table leg . It works great and does not get any cheaper.http://www.ikea.com/us/en/catalog/products/40104270NB
Bullshit. I worked for a company that makes the suspensions for your hard disc drive in your computer and we used vision to look at stuff under way amounts of magnification, granite was the base for all of our multi-million dollar machines.W
No bracing required with threaded rods and solid wood, or butcher block.
QuoteNo bracing required with threaded rods and solid wood, or butcher block.Toobluvr, this is exactly what I have in mind, but will be without the fancy brass hardware, the all thread rod will just be the zine plated stuff. Why would the sprung turntable sound better on light stand? I thought the purpose of the stand was to isolate vibration from the table , so the heavier the better, the law of physics, no magic there, am I missing something?
The unsprung tables do indeed need a heavy massive support structure to sound their best, as a rule. There are always exceptions, but I have many years of first hand experience with the Linn/Pink Triangle type tables and they do not like being placed on a heavy mass loaded stand that couples them to the environment at all!
Apparently,Sprung turntables like to have low bass garbage energy get absorbed by their bass. Also mass stores energy (maybe as heat).Did I tell you I have a granite bass and all kinds of TTs?It doesn't boil down to what each person prefers, it's about science. There isn't a table in the world that wouldn't love to sit on top of an immovable surface, that doesn't vibrate in concert with each bass note played. Whether it be a little sprung AR-XA or an Empire 598 or an Empire 398 or even a Technics DD.Wayner
