chime questions ?
0 Members and 1 Guest are viewing this topic. Read 1138 times.
harryf
chime questions ?
« on: 22 Oct 2009, 08:00 pm »
I'm 90% through my chime build.
I added connecx gold rca's instead of the stock ones.
What i'm wondering is what side is the red rca On the board?
I only have a piece i didn't use for my cornet2.I'm not sure if they are the same?
Also i forgot the ferrite beeds.Would it be ok to mount them on the other side of the board?
What is slew rate and what sounds better?
Should i try the switch i saw on a site it seems very easy to add?
Do auricaps 1 uf sund much better than a solens cap?
I can see how it might make a big difference in a amp or pre amp but in a unit thats digitalWould it not be a very small improvement??
Has anyone ever used decal inkjet paper to make decals for these units.I'm thinking of buying some paper?
