0 Members and 1 Guest are viewing this topic. Read 5132 times.
Just curious if there would be any benefit to incorporate very thin lead sheets into or onto electronic components as a tweak? Maybe to isolate certain areas internally, or components from interference?I see a lot about ERS cloth added in mod's, and chassis dampening material. Lead sheets, intuitively, seem like a combo. I know its not PC to use.... but this is the lab!-Tony
For RFI shielding almost any metal will do. Copper, aluminum or steel will be fine and thickness won't be much of a factor.Lead is not magnetic nor is stainless steel, neither will do much for EMI.The best thing for EMI is mu-metal but it's hard to find and expensive. So for EMI just use any soft steel and the thicker the better.
but if we start having problems with EMP, I'll stop posting on forums.
The use of lead is a good idea in my opinion, the only thing that will stop or slow down Gamma radiation is a decent thickness of lead. The effect of Gamma radiation upon the transistor has been studied and has been found to break down the boundries between the material layers (NPN or PNP) rsulting in noticably reduced service life of transistors. Also I believe that very small integrated circuits would be effected, with the continual reduction in size of components (now at around 100um for some) the power of Gamma radiatio to cause spurious results in digital circuits is more probable. I have wondered myself about whether it would be possible to hear the difference when a vacuum tube is surrounded by say 2.5cm of lead as to my mind the operation of a valve is more susceptable to the degrading effect of this most powerfull form of ambient rediation. Also there are hardened components that were primarily designed for use in reactors and high radiation environments such as space, these have different constructio to normal transistors/components to prevent radiation from affecting their performance. As to whether they happen to sound better in Hifi I don't know it would certainly be interesting to find out whether these differeing manufacturing techniques result in better sounding components either by chance or directly due to their improved resistanc eto degradation by background radiation.
Thanks for the humorous commonsense answers from Bill, Dan, & Pat! I'll throw in with Bill that too much damping can be a bad thing and with JimJ on cabling being a source of noise as they can make great antennas in the right conditions.Also if your curiosity is still piqued about what metal to use for a Faraday Cage, then I can tell you my research indicates copper is the most widely used and it is what I plan to use to isolate my power supply area inside the chassis of the HagTech Cornet2 phonostage I am designing. FWIW.Best,JakeJ
I think that we have some confusion here with acronyms:EMI = Electro Magnetic Interference (this is mostly power line related)EMC =Electro Magnetic Compatibility (a combination of EMC and RFI)RFI = Radio Frequency Interference From my Electronics Dictionary:MumetalA metallic alloy with a high permeability and a low hysteresis loss. It is excellent for magnetic shielding.
Quote from: Browntrout on 22 Oct 2009, 08:25 amThe use of lead is a good idea in my opinion, the only thing that will stop or slow down Gamma radiation is a decent thickness of lead. The effect of Gamma radiation upon the transistor has been studied and has been found to break down the boundries between the material layers (NPN or PNP) rsulting in noticably reduced service life of transistors. Also I believe that very small integrated circuits would be effected, with the continual reduction in size of components (now at around 100um for some) the power of Gamma radiatio to cause spurious results in digital circuits is more probable. I have wondered myself about whether it would be possible to hear the difference when a vacuum tube is surrounded by say 2.5cm of lead as to my mind the operation of a valve is more susceptable to the degrading effect of this most powerfull form of ambient rediation. Also there are hardened components that were primarily designed for use in reactors and high radiation environments such as space, these have different constructio to normal transistors/components to prevent radiation from affecting their performance. As to whether they happen to sound better in Hifi I don't know it would certainly be interesting to find out whether these differeing manufacturing techniques result in better sounding components either by chance or directly due to their improved resistanc eto degradation by background radiation.I would think that if you are really worried about this than get your hands on a Geiger counter and see what it registers. However, if Gamma radiation is a problem I would like to suggest you contact the Department of Homeland Security immediatly.Regards, Dan Banquer
