0 Members and 1 Guest are viewing this topic. Read 1452 times.
The Pro series is available in Black 19 inch rack mount faceplate only. http://bryston.ca/14bsstpro_m.html The Consumer C- Series is available with the C-Series cosmetics - in silver or black and in 19 inch faceplate or 17 inch faceplate.http://bryston.ca/14bsst_m.html The Pro series also has volume controls in the circuit path on each channel - the consumer C-Series does not. I usually recommend the C-Series if you want the simplest cleanest signal path and the Pro if you need the volume control on each channel.
Quote from: James Tanner on 20 Oct 2009, 10:21 pmThe Pro series is available in Black 19 inch rack mount faceplate only. http://bryston.ca/14bsstpro_m.html The Consumer C- Series is available with the C-Series cosmetics - in silver or black and in 19 inch faceplate or 17 inch faceplate.http://bryston.ca/14bsst_m.html The Pro series also has volume controls in the circuit path on each channel - the consumer C-Series does not. I usually recommend the C-Series if you want the simplest cleanest signal path and the Pro if you need the volume control on each channel.Thanks James, But there is nothing different in the quality of sound. They would both be just a useful in a Home as in a Concert or Studio enviroment.
