N3 plans errata (FYI)
0 Members and 1 Guest are viewing this topic. Read 1794 times.
yakman2000
« on: 20 Oct 2009, 06:53 pm »
Baffle C isn't listed in the cut list section.
there is enough info in the drawing per se to deduce it.   (6.5"x4" 3/8" double roundover)
ebag4
Re: N3 plans errata (FYI)
« Reply #1 on: 20 Oct 2009, 07:00 pm »
If you are referring to"Brace C", there isn't one, there are two "Brace Bs".  The N3 cabinet appears to have started with the AV3 cabinet that Danny has modified.  The AV3 did have a "Brace C".
Best,
Ed
yakman2000
« Reply #2 on: 23 Oct 2009, 07:59 pm »
OK.  Then the first page of the plans, (side view showing brace locations etc) shows a brace "C" that apparently shouldn't be there, located slightly below the lower brace B.
yakman2000
« Reply #3 on: 23 Oct 2009, 08:03 pm »
Looks like it got removed from the current pdf.  I'll reprint and go on with life.
Good.  The ones I did were just a tiny bit narrow and I was going to make new ones today.
Looks like I won't have to.
